darthkringle said:
One question for the seasoned board members: When "crawling for bass", does the sub only need to be in the listening position on the same horizontal plane or does it also need to be elevated vertically to ear level?
Thanks!!
You get the most accurate results if the sub is brought to the usual height of your ear, and the crawler is at the usual height of the sub. It's a pain.
Luckily, in most rooms, it doesn't matter too much. With an 8' ceiling and a 3' ear level, the floor-ceiling mode is not the biggest problem for bass; so accurate placement in height isn't that incredibly critical.
You haven't had fun until you've hoisted a VMPS "Larger" sub up onto a chair and crawled around in a large room, listening to 30Hz tones for an hour, with a test meter. I think I was gibbering by the end.
