Hi, and thanks for any help you can give me in bi-wiring my Wharfedale Crystal 2.40 front loudspeakers to my receiver.
manual for the speakers I found on the net suggests that I need to connect the wires from the receiver to the binding posts on the opposite ends of the speaker. (under
Connecting Your Loudspeakers -Standard Connections)
But that would mean I am connecting the (+) end of the wire to the
LF and the (-) end of the wire to the
HF.
That doesnt seem right? Shouldn't I be connecting the wires to the (+) end of
LF and (-) and of
LF?
(Please see pic to see what I mean).
(1) Should I follow the manual and connect (+) and (-) ends of the wires to LF(+) and HF(-)?,
or
(2) do what looks right and connect the (+) and (-) ends of the wires to LF(+) and LF(-)?
Thank you
