Hi,
Sorry if I didn't clarify the issue. PS3 plays movies fine through direct connection to the Bravia, and if autoplay, by the PS3-2310-Bravia connection. The problem is for any disk that doesn't autoplay, where because the menu screen of the PS3 does not seem to play through the 2301, it is impossible to get to the PS3 menu required. Hence connect back to the Bravia directly, navigate to where I want to be, get going, then reconnect via the 2310. Hope that is clearer.
Monitor is fine - not sure what you mean by '1 or 2'? I only have the one monitor if that is what you mean.
Are you suggesting that I disable autoplay on the PS3? I think I have tried that, but just to be sure I'll give it a try (again?) and see if it helps.
Regards and thanks.
