rustem said:
I don't know, maybe I am wrong and I don't understand something? Are you sure you can't have higher resolutions through S-Video out? Our projector connected to S-Video displays in 800X600 resolution... We even tried higher resolutions, but projector's native is 800X600, it interpolates higher resolutions.
Your projector, if it is a 800x600 resolution projector, converts the incoming 480i s-video signal to 800x600. It is a lousy way to feed the projector and will produce a marginal, at best, image. If your projector (what make/model?) is 800x600 then you should feed it 800x600 resolution for the best possible image.
rustem said:
If we get the thing you were talking about, we then would have to change the cable to the projector, and that's tricky in our case. It's pretty long, and goes though some paneling and the projector hangs very high above...
If you don't have a VGA cable already run to the projector, then this may be a bit of a task. But, if you know you are going to connect a PC to ANYTHING you always should run a VGA cable to make that connection. This is something that any experienced installer would recommend from day one when all the wiring was being done to begin with. Since it just may take an hour or two with a ladder, I would definitely go that route. Once it is in place, it is in place and you don't have to deal with it again.
rustem said:
I just hoped there would be some simpler solution. If not, we probably will go for another option - we'll connect the monitor to the VGA out, which is on the back of the projector. We already have the long VGA cable, which we wanted to connect to the laptop. We'll simply run it up to the projector.
If the projector has a VGA out, it should work as a pass-thru to allow your monitor to view what the projector is showing. This typically only works when the projector is on though, so keep that in mind. There really is not a better alternative that the loop through for the least amount of money.
You can easily pick up additional VGA cables from
www.monoprice.com which is an excellent source if you need cables of almost any length.
I believe that I would avoid the video amplifier that is recommended by billnchristy a couple posts up. You aren't dealing with standard video, you are dealing with computer resolutions. Converting a PC resolution to a video resolution is about the worst thing you can possibly do with the image and will make things difficult for audience members to read and understand.
