Hi. There are two things that I'd like to mention:
1. You should be able to get surround sound using the optical connection in the MBP. I can from my regular MB. I had to change a setting or two, though (years ago, so I forget). I found out how by Googling it.
2. The external sound card connects to your MBP using a USB port. You would not connect the audio output from the MBP to the audio input on the external sound card.
Thank you for your response!
I have been doing a ton of research on google and it is actually not possible to get Dolby Digital/DTS unless you are playing a DVD or any type of prerecorded video with Dolby Digital already encoded.
However, it is possible to get fake surround only using 2 channels if your receiver is capable of doing Dolby Pro Logic I/II.
You my friend have stated the somewhat obvious, the obvious that for some reason was clogging me up before
. So I now realize I may have asked a somewhat stupid question heh.
Connecting the USB sound card via USB to the MBP, and connecting an optical cable from the optical out directly into the receiver should do the trick I believe as long as the sound transfers through the sound card and such would I would guess it does.
If anyone could confirm this that would be super before I throw down a bunch of money to buy this card! Thank you very much!
