Hello snifferlip,
welcome to Audioholics.
One cause is that the source and monitor may not share the same electrical ground – instead, they are plugged into separate electric lines grounded on different circuits, or the cable wire itself is not grounded to the same conductor as the unit’s ground. Sometimes battery-powered images sources (camcorders, laptop computers), which share no common electrical ground with the display, introduce the hum bars. Try using the source device’s A/C adapter instead, plugged into an outlet grounded to the same conductor as the Plasma display's power cord.
Another cause of scrolling hum bars, or hum lines, is signal wires run next to A/C current wires. Take care to separate these two kinds of wires. If they must approach each other, arrange the wires so the signal wire crosses at right angles to the A/C. You may need to contact your installer or qualified electrician to fix this problem.
A third cause of hum bars is a strong motor or other interference-generating, power-hungry device which shares the same electric line as the plasma set or video signal sources.
Good Luck
Rick
