Ceiling Mounted JBL SCS160SI Problems & More
Q
qdaddyo
Hi Folks,
I moved into a house that has speaker wire coming out of four small holes (two front/two rear) in the ceiling. For the holidays, I bought a JBL SCS160SI speaker system. The mounts that come with the system are used for walls, not ceilings. Any suggestions on what ceiling mounts I can use?
Also, can I turn speakers upside-down? Will that cause any issues?
Thanks!
