Hi guys. Earlier in the year I built a TRIO12 dual APR12 SPA500 sub, in an extra large 24" cube. Unfortunately, my large room (about 24' X 14', with an opening to a hallway and back half of the room about 18' wide) requires more subbage. Since the kit with a single 15" passive radiator (PR) seems to produce similar results to the dual 12 PRs, and is quite a bit cheaper, I went with the TRIO12, APR15, BASH500 combo for $379 + tax & shipping. It really is a steal since the plate amp alone is $270. I will be making it as per the cut sheet specs: 20" box since the last one takes up quite a bit of real estate. In the future, a horn sub may be constructed if I get bored and need a new project.
I haven't made any cuts yet, but bought a new Mastercraft Maximum Router on sale, as well as a Jasper 270 circle jig. I made sure the jig made circles 18"+ in case of future upgrade builds . I don't have a lot of experience with routers, so last night was getting familiar with it, and making sure the jig fit the base, which thankfully, it did. Router bits also went on sale shortly after purchasing the router, so I got a set of 12 or so carbide tipped mastercraft bits for around $25 (regularly $90-ish).
