Hi guys,
Another question from a HT novice:
I tried to calibrate my 7.1 speakers using the AVIA disk and a Radio Shack analog SPL meter last night. I had the meter on "C" weight, "Slow" response as suggested by AVIA. But when I played the test tone, the needle on the meter remains all the way to the left (~ -10 db?). I then changed the range from 70 to 60 (lowest range on the meter) on the SPL, the needle barely budged. Is it a broken meter or the volume was too low?
The master volume on the receiver is turned to a bit louder than what I would be watching movies at (45 on the receiver display, whatever db that may be corresponding to). Should I crank it up even higher just for calibration? And would that damage my speakers (I kind of know the answer, but just want to be sure with the brand new speakers)?
Thanks in advance!
