from another post...
Heres what I use and havent had any issues as of yet, pretty future proof...
behind the tv...
Arlington ARLTVB712 Recessed Steel TV Box (ARLTVB712) from Solid Signal
at the equipment rack...
Arlington TVB613-1 Recessed TV Outlet Box with Paintable Trim Plate, White, 4-Gang - Amazon.com and install 1 of these for the speakers {even though I only run 5.1 rite now, just incase I ever want to go 7.2 I ran the wires and kept them in the wall behind the sheet rock}
Amazon.com : Pyle Home PHIW71 7.1 Home Theater 14 Post Binding/Banana Plug with Dual RCA Subwoofer Posts Wall Plate (White) : Electronics
2 of these
Amazon.com: Vanco 120614X Custom Two-Piece Bulk Cable Wall Plate (Single, White): Electronics one side gets piped rite to the tv and the other to the utility room in the basement...
then for power to the equipment rack {I keep them separate} I run one of these...
Amazon.com: Vanco TVB2GW Recessed Dual Gang Indoor InBox for Plasma and LCD Televisions: Electronics , on one side I run the std 110v double recept and the other side I run a single 220v {the small 15a plug with the 1 sideways prong} but that is just because I run 220 to some of my amps...
also I this looks interesting but never used one, I use the above unit behind the tv
Amazon.com: Datacomm 45-0031-WH Recessed Low Voltage Media Plate with Duplex Receptacle, White: Electronics
As far as conduit, I used the thin pvc they use on central vac systems {its huge} to go to the tv, then I used 3/4 to go to the utility room which I regretted when I had to run an HDMI cable from the sureillance box to the avr, I figured that conduit would only need an ethernet and a coax at the most, but nope I started wiring the camera system and then had to fight the hdmi all the way to the avr, if I put something bigger it would have saved me 3 hours and a lot of swearing, the head on the hdmi plug is big to push through small pipe... Also dont forget your string, I run a few lengths of srong string through the conduit and tie them in the boxes for later... This stuff changes all to often..
When the inspector seen what we did for the HT setup he said it was bar for the most extravagant he ever seen, but I have seen much nicer, a freind of mine has a built in power regulator filter unit at his rack that cost $1000 then he recessed his TV in the ceiling with one of them tv lifts, and all the wiring is in his attic where the tv hides when not in use... Pretty sick... He was trying to figure out how to make the speakers be disappear too, his equipment is all in a closet behind the HT...
One more thing to remember, {I learned the hard way} mark up your tv bracket first, and buy a bracket that does a large array of sizes, like 24-60 depending on what size
screen you are using} I had to move mine because we couldn't get the tv centered, had to pay the plaster to come back and repaint the entire wall because sherwin williams decided to discontinue the line we used for that room after a couple months and the touch up didnt match, not to mention I had to hear my wife complain about dust after the house was built... To this day she swears the house gets more dusty because we opened that wall back up, even though its plaster and there is no sanding involved...
