The media center cabinet in my bedroom has glass doors on the front and I'm not sure what an acceptable temperature range is. The only piece so far that is behind glass is my Onkyo TX-SR606. Typical of an Onkyo it runs warm but with 4" between it and the next shelf and four 1" vents and one 4" high in back of the same shelf it doesn't feel too hot in there. What is an acceptable temperature range? I do have a 22db 120mm 115v AC fan that I can use but it's too loud to run all the time. I'd like to install a simple switch to turn the fan on at say 100 and off at 90 but the closest that I've found is one that will turn the fan on at 120 and off at 100 - I assume that's too high. The house never exceeds 90. If I do use the fan it will be in the 4" vent hole behind the receiver. Should it be push or pull? I'd post pictures but I'm having technical issues tonight.
