- I've just purchased a Jamo homecinema 5.0 speaker system and I'd appreciate any suggestion concerning the wire I should use to achieve the best performance.
- I've noticed that Jamo speakers are 6 ohm and my sub is 8 ohm. Despite my receiver works with both impedance, should I have any problem with that?
- Also, how to convert a wire specified as 2 x 1.50mm2 to the AWG number?
Receiver:
A/V Pioneer VSX-D414 (DD and DTS). It works in 8 ohm or 6 ohm.
Speakers (Jamo):
F - 2 PJFC 4500 (6 ohm) (towers)
C - 1 PJCC 4500 (6 ohm)
S - 2 PJSC 4500 (6 ohm)
Subwoofer:
Pioneer (6") - 100W (8 ohm)
Regards.
