Now that I have a Roku and a Netflix account, I'm seriously considering cutting the cable and going with OTA TV. Since I have a projector, I would still need a HD TV tuner, so this looks good to me -
Channel Master DVR+ review - CNET
Then there's the question of what kind of antenna would be suitable. There are only 3 OTA broadcasters (CBC, CTV and Global) in my area, all within 5 - 10 miles. I'm also at the top of one of the highest points in my area. So, since the channels available to me are so close, do I need to spend much on an antenna?
The next nearest tower for a different broadcaster would probably be in Bangor, which is about 300 miles away.
Mark has it right.
5 to 10 miles is close, and you're in a high location, so even the smallest, low gain, antenna might do. You shouldn't need an antenna amp, and if you can avoid one, that's good.
I use a passive antenna with low to medium gain. In the Washington DC/Baltimore area, I can pick up dozens of stations as far away as 50 miles. I have a rotor, but only use it rarely for Baltimore stations.
The question remains, do you need to rotate your antenna to pick up those 3 local stations? Or can you aim the antenna in one direction that will work for all 3? If you're lucky, you might do fine with an indoor antenna, that you can aim manually. Low gain antennas tend to be less directional than those with high gain, so aiming should be less critical.
You also need to know what TV broadcast bands are involved. In the USA, there are 3 bands, Low VHF (channels 2-6), High VHF (channels 7-13), and UHF (channels 14 and up). In the USA, most HDTV broadcast channels are in the UHF band, but I don't know what is done in Canada. UHF signals tend to need more precise antenna aiming than either of the VHF bands. But I'm talking about about ±30°. Maybe you could aim an antenna to the SE and pick up all 3 stations.
A cheap way to find out what works in your location, is to buy an
inexpensive rabbit ear antenna, and test it.
I know a web site (
http://www.antennaweb.org/Address.aspx) where you can enter your location, and find out what TV broadcast stations are available for you, their distances, and compass bearings relative to you. But it is only for the USA.
Here is a useful online vendor:
TV Antennas & SuppliesÂ* -Â*TV Antennas - Shop at SolidSignal.com - Page 1
