Start with one blade and mount the opposite blade next, finding the one that balances best. Then, add the other two. Use the rubber bumpers to keep vibrations from being transferred to the ceiling.
i don't think that would work. as the unit is solid mounted
This really should not be a huge deal. Run you fan at it's highest speed then shut it off. This will ensure the motor housing is not tilted if you have it hanging from a rod. Get your ladder and get a ruler or yardstick and place it at the very tip of the blade and touch one end to the ceiling. Not the exact measurement. lightly rotate the blades and find the offending one... A 1/2 inch can really cause a fan to wobble at high speed. You'll likely find that all of them are off a little. Find the most off one and market with a piece of tape so you know which one it is. Grab the motor housing and the tip of the bland and give it a little nudge up or down as needed to get it into place. Turn the fan on high and see if it worked. If not, shut it down and check that blade first and measure the distance. Just adjust the blade accordingly with gentle pressure to get it's position where you need it to be. You may have to do it a couple of times to a couple of different blades, but it shouldn't take more than 15 minutes or so... 20 if you're drinking beer.
i did measure. they were all different, and random. but i didn't try bending. i will try that.
all the screws are tight. i used pennies, nickles and quarters. none seemed to make any difference. and i couldn't tell if they where too much weight, or not enough.
thanx. i will try these suggestions. if, for whatever reason, they don't work.
i will take it down and use some real metal to bolt that bish down.
btw, it is mounted to a flexi-core ceiling = SOLID.
