First of all Shamus, sorry for the delayed response; I had guests.
shamus said:
...are u saying all speakers if wired correctly will be in phase with the sub?
Not quite. If all speakers are wired correctly, they will be in phase
with each other. The sub is different for two reasons:
1. It is not usually wired like the other speakers, but powered independantly and fed it's signal through a coaxial digital cable.
2. It is the only speaker that will have some form of phase adjustment capability, either through a switch (to select either 0 or 180 degrees), or a rotary (to select anywhere between 0 and 180 degrees inclusive, i.e. greater control than a switch).
shamus said:
...ive got all speakers in phase with each other... checked the avia phase pattern(and even thx)....for some reason when integating the sub (actually 2 subs, front and back) it throws either the center off or the l/r mains (surrounds are hard to tell) i even ran the frequency sweeps and it shows a big drop off in the middle range
It sounds as if you are simply struggling to integrate the subs with the other speakers. If the (correctly wired) speakers all sound fine with the Avia calibration disc
with the subs off, then that is probably the most likely explanation.
shamus said:
...am i understanding sub phase correctly??? it has something to do with canceling each others frequency? sorry to be a pain but please help!!!!
Don't worry Shamus.
My advice is:
1. Wire up all speakers correctly (leave the subs switched off for the moment).
2.
Listen. Do the speakers sound ok? They should.
3. If the answer to 2 is yes, then
now switch on the subs. It is only by experimenting with the subs placed in various locations , and possibly with the phase control that they would be found to be in-phase. Just put them in a position and with the phase control set to where music/films sound good. That is all that is required.
3db said:
The subwoofer is responsible for bass and bass is supposed to be omni directional. So from that premise, does it matter that the sub is in phase with the rest of your speakers.
It is difficult to tell where
deep bass (i.e. from about 60Hz and below) is coming from, but it still matters (depending on how one feels about the issue
) that the sub is in phase because there's more than one speaker in the room.
3db said:
I have the Sound & Vision test DVD and used the phase control on the sub to achieve max SPL at my seated position and not to achieve phase with the other speakers.
Why would you use the phase control to achieve a maximum SPL? Why not just use the volume knob on the sub itself?
shamus said:
it is crucial because you may lose a lot of the frequency where the speakers cross over with the sub.
I wouldn't quite say that.
Remember, the front mains will cover from (in your case Shamus) 90Hz to 20kHz. The subs are therefore covering up to 90Hz. In other words, the sub covers less than 1% of the sound of the mains!
3db said:
You won't lose any frequencies because they are out of phase. There still there, just out of phase is all
In practice, true, but in principle, two speakers facing each other wired 180 degrees out of phase generating the same sound,
would cancel each other at the point of collision of sound.
mulester7 said:
.....you guys are trying to please a meter.....now picture how fast those cones are going back and forth.....do they blur or not?....you move away from 0 concerning sub phase-control, and you're taking authority away from the subs....
You know I don't want to argue with you Mulester7,
but I must disagree here. The way I see things, a good methodology for setting up one's system is to set it up 'by the book' and tweak from there if desired. In this way, a datum is first established by which tweaking may then be compared and judged.
Moving the phase control away from 0 degrees may cause a lack of authority to be introduced in your own room, but wont in all rooms.
mulester7 said:
...my view on out-of-phase speakers....please your ears...
There's always that.
At the end of the day, if tweaking is a person's 'thing', then by all means tweak to your heart's content. If nothing else, it can make life much easier.
shamus said:
all i know is my next receiver will have an automatic room correction setup device so i wont need to go through this again!!!
It's not so bad. All it takes is a little experimenting and/or reading. I hope this helps a little.
Regards
