> "But this is just foam! Why so expensive!" Is there anywhere I can buy the same material for way cheaper? <
A better question is probably:
"Is there anywhere I can buy something much better but for the same cost?"
Otherwise, your best option is to DIY some panels using rigid fiberglass wrapped in fabric. That is better than foam, and it costs less too, but you have to do more work.
--Ethan
