Thanks...now last question. I'm confused about digital coax and component cables (used for component video). Are they the same, just used for different things? For my sub-woofer I am using a component video cable that I have no need for. Should I get a digital coax instead?
Thanks!
Oh my god... shoot me!
THESE CABLES ARE EXACTLY THE SAME!
See this cable...
http://www.bluejeanscable.com/store/digital-audio/index.htm
It's the EXACT SAME as this cable...
http://www.bluejeanscable.com/store/composite/index.htm
Except on is orange the other is yellow.
Those are single version of the EXACT SAME...
http://www.bluejeanscable.com/store/audio/index.htm
Alright, a slightly higher grade coax is used for the audio for shielding, but the 1694A Belden cable is freely recommended as well.
How about component video?
Once again: EXACT SAME!
http://www.bluejeanscable.com/store/component/index.htm
These cables are all interchangable with one another. Run out of component video cables? Use a subwoofer cable, and two 'digital' audio cables. Run out of composite video cables? Use one side of a stereo analog audio cable. Run out of RGBHV cables? Use 5 composite cables!
The key is using a quality cable and realizing that they are almost all identical. The concept of a 'digital specific' cable is marketing at its finest and should not be confused at all with reality.
It's very important to realize that from a good company, you should expect an analog audio cable to be of HIGHER quality than a digital audio cable. As is shown on Blue Jeans cable - the analog audio cables are about $19 per piece (a pair for 38 bucks) at 6 feet, while the digital audio cable is $15 for 6 feet.
So you are getting doubly played over if you pay 'more' for digital. Digital is far less open to interference and passes a signal far more easily, so a lower quality (overall) cable can be used. Yet, at the end of the day, you are very unlikely to hear a difference between almost any decently built 75 ohm cable with RCA ends on them.
For your subwoofer - a decent ANALOG audio cable or ANALOG video cable is likely a far better choice than a digital cable since it may (MAY!) have more shielding on it to protect the analog signal from interference.
The "HIGH QUALITY" Monoprice cables are a very strong recommendation for your consideration:
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10236
6 feet of RG6 for $3.20 - 25' for $6.16... call it a day.
