Audio Quality fo 3.5mm V. Dock
ACsGreens
Hey All,
I am trying to figure out what the audio quality difference is between using the 3.5mm headphone jack versus the docking method for iPad's, iPhone's, etc. I was using MOG the other day, which I love, and have turned on the high quality streaming option, which on wifi or 4g allows you to stream 320kb over bluetooth or headphone. I was listening on the Studio 60's with Yam rec, and it just did not sound very good. Any thouhts?
AC
JohnA
JohnA
If I am not mistaken using the dock connector in either a dock or a cable adapter bypasses the internal headphone amp and provides a better signal.
bikemig
The 30 pin dock connector is better than the headphone out. For the best quality sound, I'd get a dock like this pure i20 dock: Amazon.com: PURE i-20 30-Pin iPod/iPhone Speaker Dock: MP3 Players & Accessories
That way you bypass the internal dac on the ipod. The HRT istreamer does the same thing: Amazon.com: HRT iStreamer Outboard DAC for iDevices: Electronics
It is future proof in that it would work with the new lightening dock as well since it has a usb input. I'm leaning towards the HRT iStreamer for that reason.
macddmac
macddmac
Stream via AirPlay to the receiver? Works great!
avengineer
The 30 pin dock connector is better than the headphone out. For the best quality sound, I'd get a dock like this pure i20 dock....
That way you bypass the internal dac on the ipod. The HRT istreamer does the same thing:...
This implies that using the dock connector always bypasses in internal DAC, which isn't always true. There's a lot on that 30 pin connector, including line level audio, line level inputs, video outputs, USB data and various mode-switching pins. It's possible to get just line level audio out of the connector, which is a little better than the headphone jack, not because the internal headphone amp is poor (it's actually darn good), but because the line out bypasses some additional processing used for headphones, like volume control and EQ for example. In general, the line output function provides no volume control, though there are docks (including a Universal Dock from Apple) that have IR remotes with volume control functions. A simple audio output dock cable will provide a fixed line-level analog output.
The analog line out is quite good. There are small gains to be had via USB data from the dock connector, which means you get the audio data out instead of actual audio, and then need an external DAC. The internal DAC isn't bad, though. When a device that uses USB data as the audio out function states that you can get the iPod function as well as Pandora and Rhapsody etc. out of the device, it's not always a smooth ride. Some generic USB DACs cause a bit of a control struggle for the iPod or iPhone that can be frustrating. The iPhone app might not always recognize there's a USB DAC out there to play to, and you might have to "trick" it into doing that. I have a car stereo with a USB dock cable that has this issue. You can get Pandora to play out of the USB cable, but you have to jump through a couple hoops to do it. It's a problem that you won't run into using the line output on the dock connector, only the USB data output.
Depending on how a device uses the dock connector's switching and sensing pins, you may get a compatibility error message on your iPod/iPhone screen, though in reality things work fine. Generic USB devices sometimes pop the error message because they aren't triggering the switching/sensing pins correctly. Even a line-out only dock connector, when used to also charge the device, can pop up the error message. You can just dismiss the error and get on with life, though.
Theoretically correct, though I'm not sure all the combinations have been tried yet.
bikemig
@avengineer: Just to be clear, I wasn't implying that using the 30 pin dock connector bypasses the iPod's dac. I was simply pointing out that there are devices that allow you to bypass the iPod's dac.
By the way, I agree that the analog out from the iPod is pretty good and I use it all the time when I travel. That said, I've always been a bit disappointed in the SQ when connecting it to a good music system using just the line out. I think you can do better but I prefer to rely on a computer as a source in this scenario over the iPod.
avengineer
Sorry, I didn't mean to imply you were wrong, just being detailed. It's a fault.
Agreed, though I've been fairly satisfied with lossless files out of the line out. Where I get a little uncertain is the benefits of a cheapie USB DAC over the internal one...not sure that's worth it, but a good external DAC should always win in SQ.
By the way, ever tried Bluetooth stereo audio? I've found, since it's another form of compression (misusing the term here, but you know...) if your files are low-rate .mp3 or even .AAC files, Bluetooth makes them much worse. Lossless files don't seem to take as much of a hit though. Figures, if you think about it. The lure of wireless audio connections will get some people to jump at it, but it's not the best way to get audio out of your iPod.
ACsGreens
Have you noticed a celebrity on tv and considered, "I would like to have what she or he is putting on"? In that case, you then have been in luck It's quite very easy to have design that matches the fashion of your preferred famous people Below are a few trend tips which can help you accomplish a Hollywood seem thenorthfaceoutletcity com/]thenorthfaceoutletcity com
Accessories are other people you know You are able to acquire any aged outfit that might be really dull or ordinary by itself and dress it up with remarkable accessories Add more the perfect pendant or brooch to a little black color outfit, and you've undertaken that LBD from common to awesome by two seconds flat
Pick top rated or bottom to showcase sexily, but in no way each The line among looking sexy and seeking trashy can be very slim nonetheless, this principle should be sufficient If you showcase your higher or reduce system, keep your other one half stylish, yet conservative Take into account, this rule relates to men or ladies
When you are uncertain what colour shoes or boots to utilize using the attire you have in mind, you should think about putting on nude pumping systems These comfortable shoes choose nearly what you set them You will additionally have the included bonus of which creating your thighs appearance for a longer time and thinner
When hemming your jeans, take the elevation of your respective shoes or boots under consideration The hem of your own jeans should invariably be half to three fourths of the inch off of the flooring Keep two lengths of jeans Have trousers that you can wear heels with and versions you can put on with smooth footwear
You need to have no less than a few hand bags in your wardrobe The initial bag must be a typical, leather ladies handbag with traditional lines for everyday use The subsequent ladies handbag ought to be a huge tote-style ladies handbag to use on these relaxed time when you need to seize and go You must also possess a modest clutch for all those special occasions
In case you are a mom, design is one of the very last thing on your mind, But know that it must be easy to look good and functional concurrently Regardless of whether utilizing the little ones for the playground, sports events or another function, liven up your look with a wonderful T-T-shirt, knee-duration skirt and a couple of toned sandals!
Sections of makeup products are not an appealing seek out woman In reality, recent polls taken by gentlemen learn that the much less makeups, the higher This does not necessarily mean that you must avoid makeup products altogether try to use cozy shades and placed on merely one level of mascara and eyeliner
Avoid gaping switch-lower shirts with a little bit of velcro or tape For any long-lasting correct, sew little strips of connect-and-loop between the control keys throughout the bust of your tee shirt Should you aren't helpful having a needle and line, you can even use tiny items of dual-sided tape Make sure to take it off prior to washing the tshirt, even though
It's fine to mix up designs and colours within your design choices A lot of people think that layering a produce in addition to yet another printing is really a design no-no, however it can work and check really elegant Just ensure that your outfits have vintage facial lines It's when you've acquired numerous designs and crazy clothing forms that this design law enforcement can take discover
Don't be scared to accessorize The right adornment can change the normal attire into a trend declaration Pick a exciting accessory and allow it glow Attempt adding a colorful scarf, an entertaining chunky necklace or a blinged-out buckle Be cautious although, when one particular eyes-finding adornment can boost an ensemble, don't go crazy You need your part to serve for an vision-catcher
In choosing clothing, take into consideration what period you will be If you look great in reds and oranges, you are a "summer season" and in all likelihood will appear excellent in virtually any warm shade (like yellowish) If you look really good in blues, you might be probable a "winter season" and search good in whites and greys too
thenorthfaceoutletcity com/#403]the north face outlet Make sure that you are being strategic when selecting just how much pores and skin you wish to demonstrate This is very important simply because you ought to be certain that you are not heading past exactly what is considered stylish with regards to the quantity of coverage you may have A wonderful way to assess this really is to emphasize only one function of the body
Since you've read through this report, you should have a much better self confidence relating to fashion and your own private flavor Design is way better if it's distinctive, and you may do that because you're an exclusive particular person Keep in mind the advice and tips you've read in this article while you work at style in your daily life thenorthfaceoutletcity com/]thenorthfaceoutletcity com
onewattephend, what you've just said is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
avengineer
I don't feel dumber, I feel educated. I've learned not to pay attention to every post.
