Wow....I seemed to have forgotten about this thread.
Sorry about that, sthayashi.
Ok after a bit of experimenting and garnering info from around the net...here's a break down on using Canare ends and the various die's and ends you need for Belden and Canare cable. Some of the info for suggestions on what wire for digital cable and for interconnects was found on Blue Jeans site as well as
Jon Risch's site. Yes...I already know he has his detractors here....to bad, as I feel he does contribute to the audio world in a way that the naysayers don't.
Anyway.....IF you just feel you CAN'T solder...(it's really not that hard..really!) or you just like the looks of the crimp on ends...(Canare ends really ARE nice!) then here's some info on where to get the tools and ends.
First off the handle. You can use the Parts Express handle and save a wad...Remember to increase the crimp squeeze by resetting the dial to about it's third setting on the handle. This is about right for the two different dies if your going to use multiple cables....
www.***************** Part number 360-680 for the handle.
The dies...You can save some money by using the Paladin dies with the Parts Express handle.
Paladin
Die number 2649 and number 2657
Westlake Electronics listed above, sells both dies. This company has GREAT service...
The rest of my post is just copied and pasted from a hoge poge of things I've posted before....
Beldon Cable 89259
Use Canare RCAP-C4F Paladin
Die number 2649
Belden Cable 1505f for flexible digital cables.
Use Canare RCAP-c42 Paladin
Die number 2649
Belden Cable 1694a and 1695a for digital cables. Probably better than 1505 f but not flexible.
Use Canare RCAP-C53 Paladin die # PA2657
For Canare LV77S Great for sub cables as it's a double shield and very flexible.
Canare RCAP-C77 Paladin
Die number 2649
For Canare L-5CFB RG6 Paladin Die number 2649 Great for digital cables.
RCAP-C5F
Beldon 1694a for digital is what's recommended but I've done several with Canare LV77-s with what I view as great results.
I have some friends who live throughout the midwest and east coast who I've make a few cables for who insist on Beldon Mic cable. This stuff sells by cents for a foot of it. They all have some very exotic equipment and swear by this cable. My listening test are that yes...it's as good as what's listed above but you will have to solder ends on it.
Beldon 8451. This is a shielded design and very small.....
Again, you don't have to crimp this cable as it'll solder just as easily but the RCA ends will probably cost you more than the Canare ends..
Dressing them up? Cable Organizer has tons of different Tech Flex in colors and strips. They also carry a lot of different types and colors of shrink tubes. Of course none of the dressing is needed unless you have cables showing and want to dress them for the WAF.....
I've also been playing around with a couple of different types of silver interconnects...The Van Haus recipe being one of them. It's a NICE interconnect but isn't a very easy one to make.
