Any help with a poolside speaker
ematthews
ematthews
Looking for a blue tooth speaker for poolside play. Of course being a HIFI type person I am looking for good sound that is clear and balanced. I will be streaming music from an Iphone or Ipad. Should play loud enough to be able to speak over an AC unit and kids playing around the pool. Any suggestions? Max 300 budget. Below 200 would be better.
ematthews
ematthews
Thanks. Looking for something small with real good sound and easy BT connection. JBL Charge 2 looks ok, but I hear when turned up it distorts.
afterlife2
afterlife2
Do you want to mount it? Any info will help.
ematthews
ematthews
A portable one that I can take outside each weekend is fine. No handles or any mounts are necessary Sound quality is most important to me.
davwaymoore
This is outside your budget but they may have smaller units that also work very well. Soundcast - Outcast.
I have the Outcast and it is amazing around my pool and at tailgates!
Speedskater
Speedskater
Way off topic, but:
Any time you have audio equipment near a pool, make sure that it's protected with a GFCI outlet.
ematthews
ematthews
I ended up with a Riva Turbo speaker. Best sounding BT speaker around.
