In my main 2 channel system, I use a
Crown K2 power amplifier to drive
Apogee Stage speakers. This particular Crown does not use a fan, so there is no fan noise. It works very well and sounds great. These speakers, by the way, are generally regarded as some of the most "revealing" that you can buy, so I assure you, you do not need to be buying a very expensive ąmplifier.
In my home theater, I just use my receiver to drive the speakers there (which are
not 3 ohm Apogee Stage speakers). Unless you have very inefficient or difficult to drive speakers, you very likely do not need to buy a separate ąmplifier. You only need a separate ąmplifier if your speakers require it. Otherwise, it would be a waste of money to get one.
So, what speakers are you planning on using? That is the first question. After that, if one is needed, I recommend buying based on its ability to drive that particular load, and not wasting money on expensive brands. My Crown is very good, and I am glad I bought it. Spending more would have been a waste of money. And with my home theater, I am glad I did not waste extra money buying something more than just my receiver.
If you want really good sound and have extra money to spend, look at more expensive speakers. They matter far more than most electronics.
