I have a Yamaha RX-V465 it is a 5.1 receiver and it has a pre out on the back to make it a 7.1 I have ended up buying a used kenwood km-209 power amp and connected the pre out to the kenwood it works but the problem is i can not hear anything from the rear speaker unless you put your ear right up to the speaker. Before i hooked up the pre out to the amp i used an ipod to test the power amp and it was loud not an extreme loud but loud enough to fill the room and you can even see on the front of the kenwood its very low as the leds do not go up/down at all so i would like to know if any one knows what i could do to increase the volume to the rear speakers.
