I should also add, that the fact that these speakers do not need a sub, is why I was curious about choosing a kit with larger woofers, hence the question about 2 way vs 3 way. I can see smaller woofers handling midrange better because they are closer in size to mids in 3 way speakers. But a lot of the larger woofer 2-way kits, have those compression drivers, which is something else that is new to me as far as what all handles mids and highs.
Greetings!
If I understand well, you are still looking for decent speakers to operate in a rather small room.
May I suggest a 2-way system, an MTM configuration which I used a little while ago and which worked pretty well indeed. It consisted of two Morel CAW638 woofers and an Airborne RT-4001 tweeter, an air motion ribbon tweeter, mounted in a 43 liter cabinet. That system had a rather smooth response with a stereo sound image which was amazingly improved because of the wide horizontal dispersion of the ribbon tweeter.
Please note that I obtained a very smooth bass response down to below 40 Hz, which is very good for 6½ inch woofers. Please also bear in mind that those systems have a 4 ohm impedance and your amplifier should be able to handle such low impedance.
I had to depart from them because of space limitation, but I was really deceived by the situation.
So, I sold the speaker units separately but kept the crossovers which I had built and which don't serve me any longer. Should you be interested in trying the above mentioned transducers, I would be willing to sell you the crossovers at a very good price. Please note that the excellent Solen capacitors and air core inductors were used to build them. I designed them myself using the Harris Technologies X-Over Pro software as a starting point, and voicing the whole response in order to obtain a very good performance.
The Morel transducers are easily available, but you can purchase the Airborne tweeters from Madisound or from Solen Canada (Solen.ca)
If my proposal did instill your interest, I could arrange to send you a copy of the impedance curve which I obtained from the speakers which I had. As a matter of fact, those enclosures were heard by some of my friends who liked them, and I also received congratulations from the people at Solen, the company that manufactured the components, with regard to their impedance and phase curves.
Cheers,
André
