Vaughn: Depending on how deep you want to get into it, I would reiterate my earlier suggestion of Kuttruff's book. Beranek's
Acoustics is also a basic must-own in my world and covers room resonance in detail. Last, but by no means least, Newell's
Recording Studio Design is a great reference and is less theoretical than the former two. (Of course, I realize it's a bit out of place here in HT-world!
) Any/all should give you much more detail and explanation on room resonances and boundary interference. If you like, I can also give you some references to numerous papers, but most are not available for free anywhere online. Let me know.
Ethan: As I mentioned, I find no fault with your experiment. It's a pretty decent theoretical study. I also believe blanket application of this sort of theory to practical situations should be avoided in public forums like this. It can sometimes cause confusion for folks just trying to understand enough to help their room sound better. The "bringing up" of the null as you described can occur to a degree in real-world applications, but not "exactly" as you described. Let me try to walk (or crawl) through what I'm getting at:
Ethan Winer said:
For example, if a material absorbs only 0.25 at a given frequency, that reduces the strength of the reflection by 3 dB.
Now, for starters, an absorption coefficient of 0.25 would imply a reduction of a little more than 1 dB in accordance with the science you are assuming, not 3 dB. That minor issue aside, it is extremely important to point out that the science involved:
(a) Cannot be applied using published absorption coefficients for most, if not all, acoustical materials and
(b) Is only relevant if the absorption coefficient is measured at the frequency of interest.
Regarding (a):
Normal incidence absorption coefficients are rarely, if ever, measured and published for a material. The absorption coefficients that are published are for
random incidence - the "chamber" method. They are most often published in octave bands, but sometimes in 1/3-octave bands. The usage of 0.25 as you've implied in the above quote would only be applicable for a
normal incidence absorption coefficient.
Regarding (b): Even if the
normal incidence absorption coefficients were readily available, they would most likely have been measured using (only) the center frequency of the 1/1- or 1/3-octave test band. If there were a boundary problem in a room at, say, 117 Hz, there would be no easy way to know how well the absorber in question would "bring up the null,"
if at all! The 4" absorber you mentioned might very well perform fine at 50 Hz, relatively speaking. But at 5
5 Hz, the performance could be nil. I have done quite a bit of FR "before and after" testing by analyzing a single reflection from a wall, similar to the "parking lot" method you describe above. I have seen this radically cyclic performance of good/bad/good/bad/great/horrible over a very small range of frequencies. And in the low
and high bands.
I hope this helps clear up my thinking. I hope I didn't confuse things too much...
