Out of the box, the AQ SmartSpeaker will stream from you iDevice/iTunes via AirPlay or your Windows 7 machine via Play To. With a DNLA certified Android streaming app on the horizon, the AQ SmartSpeaker is the most compatible wireless speaker we've ever seen. For $179 a pop ($349 for two, $675 for four), the AQ SmartSpeaker is an easy way to add a whole home audio system without wires. With each of the speakers able to be set in mono, left, or right modes, you've got a multitude of options. A 3.5mm jack allows you to take the speaker with you. It all sounds great. All we need to know now is how the AQ SmartSpeaker sounds.
Discuss "AQ Audio SmartSpeaker Preview" here. Read the article.
