I would pm TLS guy, hey seems to be very knowledgable re: well, everything![]()
I have a Micro Seiki MB-18 turntable I bought back in the 1990's at an estate sale. I got it cheap as it needed a cart, but it spun and was in decent shape. I never used it, and it has lived in a closet since its purchase. Jump forward 20 years, I installed a new cart on it and I noticed that the counter weight is not the correct counter weight, in fact it is something that has been Jerry-rigged. So what to do. Can I get a different tone arm for it or maybe a counter weight that is correct to make this a working turntable? I hate to discard it, even though it's a budget table. I don't want to invest much into it since it is an inexpensive TT. My goal was to set it up with my old Sansui receiver and my Teac tape deck with some old Kenwood speakers in my office.
macddmac should be listened to
Bump
bump
bump
Grador is looking for a job at AH
Even if the counterweight is jerryrigged is the tracking force correct? Could be perfectly usable.
HT: Samsung LN32B460 32" LCD (greyscale calibrated) | AVR: Yamaha RX-V765 | L/R: Emp E55Ti | C: Paradigm Center 1 | Rears: Sony Junk | SW: Klipsch RW-10d miniDSP | Sources: Acer Revo Ion running XBMC with mySQL library server and 4 TB HDD, PS3, Technics SL-Q2 TT | 2x Aura Pro Bass Shakers
Bookshelf: Yamaha RX-V992 | Paradigm Mini Monitors
Shelved for now: Paradigm 11 SE Deluxe
Good photographs of the turntable in its current state would be helpful, especially pics of the rigged counter weight.
Since it does not have the original counterweight, you will need one of these.
Now if the current system will allow the arm to balance in the neutral position and then allow setting of the correct tracking force with the gauge, that is most of the battle. However the counter weight must be decoupled from the arm, by a spongy rubber bushing between the counter weight and the arm.
Marantz DV 9600 Oppo BD-83 Marantz AV 8003 Quad current dumping amps X 7 Direct TV HD 20 HD DVR Carter audio workstation RME Fireface 800 Fujitsu 50XHA40 Front left and right Carter dual transmission line studio monitors MK II. Center Carter coaxial transmission line center speaker Rear Carter NFM-1s Center backs Carter dual transmission line studio monitors MK I. My system: - http://mdcarter.smugmug.com/gallery/...27077317_Pufg7
Actually not all arms need a decoupled counter weight. However most pickup arms are highly problematic.
The type of tube arm in the turntable in question with detachable arm really sing in the 200 to 300 Hz range. Decoupling the counter weight helps lower the Q of this resonance.
Basically moving magnet high compliance cartridges need low mass, low inertia tone arms.
The highly touted very expensive moving coilh medium compliance cartridges need higher mass tone arms.
Turntables are much more complex than they seem. The arm cartridge combination is critical. Almost always there is serious mismatch compromising performance. Ideally the arm and cartridge should be designed as a unit like the old Decca ffss arms and cartridges.
The SME series III arms were designed with the Shure V 15 series cartridges in mind.
I think the best moving magnet cartridges outperform the expensive moving coils.
In my view the Shure V15 xmr was the finest cartridge ever produced. To really optimize this cartridge it needs to be mounted in an SME series III arm with the correct damper in the silicone fluid bath.
I think a Shure V 15 V 15 xmr correctly set up on a SME series III arm and a good turntable gives the best results it is possible to get from LPs. It is way ahead of the pack.
Visitors are astonished at the LP quality here. It occurs because of the selection of the correct equipment.
If you want to get the best from modern moving coil cartridges then you need an SME V series arm. These do not have or need a decoupled counter weight, and in fact should not have one.
Turntables and cartridges are a definite area where paying a lot more for the right equipment pays dividends.
To find a good used Thorens TD 125 and an SME series III and a Shure V 15 xme will cost you a pretty penny, but in my view that is as good as it gets. The first two items are not hard to find, but the Shure is. However the Ortofon Black moving magneth is very close to the spec of the Shure and is a very good alternative.
Not wanting to blow a wad of cash on this turntable, just get it setup better than what it is, what do you suggest?
Hard to know without having the unit in front of me. But your essential equipment is the stylus force gauge I linked so you can set the correct tracking force. You will need an alignment protractor to correctly set the tracking angle. You can download one free form the Vinyl Engine.
It looks from the pictures that there is a soft bushing between the arm tube and the counter weight. Is that correct? If that is so, then after that you are home free.
You won't spend a wad of cash, as you will not find the parts. This restoration will be down to skill and creativity.
96cobra10101 (03-19-2013)
