Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Help choosing Media streamer
  1. #1
    Hostility's Avatar
    Hostility is offline Full Audioholic Hostility is looking for a job at AH
    Join Date
    Dec 2008
    Location
    Peterborough, ontario, canada
    Posts
    351
    Thanks Given
    33
    Thanks Received
    14
    Default Help choosing Media streamer
    Well this weekend coming up i was thinking of picking up the WD live media streamer. Ive been trying to do as much research of them as i could but figured id ask if anyone can think of a better option.
    What i need and what i want it to do: Stream music from my pc to my HT. I want to be able to stream off of Hypem.com (music website). Stream Flac files, and dvd,BD rips.
    More so i want it for music as right now i just use an external hard drive to watch movies off of. Would also be nice to not have to have my tv on to stream music.
    Theater/tv * Anthem MRX300 * Emotiva XPA-5 * Pioneer BDP320 * Belkin PF60 * Xbox 360 * Samsung 6550 plasma * Paradigm studio 60v4, cc690v4, atomv6, 2 x SVS PB12-NSD's
    PC * Emotiva XDA2 * Emotiva MiniX * Paradigm mini monitor v7
  2. #2
    Greg Campbell is offline Audiophyte Greg Campbell is a forum member in good standing
    Join Date
    Jan 2013
    Location
    Spring, Texas, United States
    Posts
    9
    Thanks Given
    2
    Thanks Received
    0
    Default
    Before trying this, I would audition XBMC and JRiver Media Center (do a Google search and download them from the net). XBMC is free and JRiver has a 30 day trial and is relatively inexpensive after that. I use JRiver and it does everything a media streamer does off your PC at a very high quality. You just run an hdmi or PCM line to your receiver (I use a DAC between).
  3. #3
    adwilk's Avatar
    adwilk is offline Audioholic Ninja adwilk should be listened to
    Join Date
    Jan 2006
    Location
    Off Axis
    Posts
    4,702
    Thanks Given
    3,224
    Thanks Received
    2,340
    Default
    The WD device works great in my opinion. I like XBMC A LOT as well, but the WD is dummy proof to set up. XBMC is a little geekier IMO and requires a little hardware knowhow and some configuration. You can use the "play to" function from Windows for most music or set up appropriate shares. WD handles this easily. Theres also a fantastic smartphone app available for the newest Live Media Streamer (not live or live plus) and media hub. It would allow you to browse media and play it using your phone or tablet as a remote. Great feature. I have had multiple WD media players. The newest easily being the best.
    If you want something inexpensive and super nerdy- check out XBMC on Raspberry Pi. Took me a while to get configured (DVD/BR folders also require additional MPEG2 license) but now I love it. I like the XBMC remote apps a little better and I leave the Pi in my main system on all the time- with a WOL packet to my receiver (still testing- its not always right) and it reads and plays my mediamonkey playlists. For music- I honestly can't imagine a better setup for me.. can control from every smart device very intuitively.
  4. #4
    Hostility's Avatar
    Join Date
    Dec 2008
    Location
    Posts
    351
    Thanks Given
    33
    Thanks Received
    14
    Default
    i tried Jriver and didnt notice any diffrence in quality against winamp. I will check out what xbmc is all about, thanks (also i dont want to run a cable from my pc)
  5. #5
    joeschmoe18 is offline Audiophyte joeschmoe18 is a forum member in good standing
    Join Date
    Feb 2013
    Posts
    6
    Thanks Given
    0
    Thanks Received
    0
    Default
    Look into Synology DS412+...It is awesome and does so much more than just stream music!!
  6. #6
    Hostility's Avatar
    Join Date
    Dec 2008
    Location
    Posts
    351
    Thanks Given
    33
    Thanks Received
    14
    Default
    after doing a bit more reading i might even still just go my old school route and buy a very small slim external hard drive and manually transfer and just plug into my tv to send to my receiver. My internet gets choppy and laggy at times so still unsure how a media streamer would work in my situation. I really like the apple tv but hate how it wont place flac, and feeling a tad lazy to transfer to aac. Im also only really looking to spend around $100 but would stretch it to $150.
  7. #7
    adwilk's Avatar
    Join Date
    Jan 2006
    Location
    Off Axis
    Posts
    4,702
    Thanks Given
    3,224
    Thanks Received
    2,340
    Default
    Is your internet choppy because of the service or because of your local network? Will your Anthem do any streaming? Will the potential stream to device be wired or wireless?
    What do you use to play the music locally on your PC? Whatever program you use might have some determination on the best device to stream to. Am I understanding right that you're thinking of just plugging a hard drive into your tv to play through your receiver? Will your TV play or pass through FLAC?
  8. The Following User Says Thank You to adwilk For This Useful Post:
    adk highlander (02-12-2013)
  9. #8
    ousooner2's Avatar
    ousooner2 is online now Audioholic ousooner2 is considered a mentor
    Join Date
    Aug 2012
    Location
    OKC
    Posts
    185
    Thanks Given
    9
    Thanks Received
    28
    Default
    I purchased the WDTV-LIVE for those exact reasons. I didn't know anything about streaming devices and did a little research for a week or so. I picked up the Roku2 XS and it was just meh. Felt cheap, didn't play all the formats I thought it did, etc. All my music is in FLAC/WAV and my movies are .mkv or other blu-ray rips. I needed something that would play basically every file out there without hiccups and not have to worry if I got the right file type, etc. The WDTV Live has been great so far! It's played everything perfectly with no lagging or buffering. I'm using a wireless connection with my PC/router being roughly 30-40' away and a through 4-5 walls (cox internet w/ around 30-35 download and 4-5 upload)
    The unit looks nice also. Very sleek with gloss and matte black. The small LED on the front is super bright if you were to leave it on or visible while watching something. I believe you can turn it off at all times or have it come on when the unit is off (don't quote me on this). Anyways, just figured I'd chime in a say I like mine a lot. Best $100 I've spent in awhile!
    HOME SETUP
    Denon 1712 / EMP e55ti / EMP e56ci / EMP 5bi / subless
    '04 Acura TL
    Image Dynamics / JBL MS-8 DSP / Dynaudio / Audison / SDS
  10. The Following User Says Thank You to ousooner2 For This Useful Post:
    adwilk (02-12-2013)
  11. #9
    Hostility's Avatar
    Join Date
    Dec 2008
    Location
    Posts
    351
    Thanks Given
    33
    Thanks Received
    14
    Default
    Quote Originally Posted by adwilk View Post
    I believe my internet is choppy because we have so many users. I have my computer, landlords, 4 cell phones, and possibly a 3rd pc. Plus im in the other end of a bungalow in the basement on wifi. I would be using the streamer on wifi. I wish i could plug in as it would help so much with my connection. Im just unsure of my tv passing flac through. That just may be something i have to live with at the time being. My anthem wont stream.
    I would like to try the WD live but if it wont work that great that i dont want to be stuck with it. Plus i dont want my movies to be buffering all the time.
    I did a pc speed test and this is what i got.
    Ping - 79 ms
    Download - 3.14 mbps
    upload - .47 mbps
  12. #10
    Grador is offline Audioholic General Grador is looking for a job at AH
    Join Date
    Feb 2012
    Location
    SoCal
    Posts
    1,265
    Thanks Given
    183
    Thanks Received
    326
    Default
    Quote Originally Posted by Hostility View Post
    Ping - 79 ms
    upload - .47 mbps
    Those numbers are completely irreverent for streaming files from your PC, but that down speed is really pushing the edge of getting a good video from the internet.
    HT: Samsung LN32B460 32" LCD (greyscale calibrated) | AVR: Yamaha RX-V765 | L/R: Emp E55Ti | C: Paradigm Center 1 | Rears: Sony Junk | SW: Klipsch RW-10d miniDSP | Sources: Acer Revo Ion running XBMC with mySQL library server and 4 TB HDD, PS3, Technics SL-Q2 TT | 2x Aura Pro Bass Shakers
    Bookshelf: Yamaha RX-V992 | Paradigm Mini Monitors
    Shelved for now: Paradigm 11 SE Deluxe
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
