Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: $2,500 Recommended 5.1 Surround Sound System
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow $2,500 Recommended 5.1 Surround Sound System
    If you have $2,500 to spend on a 5.1 surround sound we can't think of any better system to buy than this one. $2,500 is absolutely everything you will need, including cables, power protection, and Blu-ray player. Just add a TV and you will have a completely new home theater. We hand picked every product in this system because of their extremely high performance vs price ratio. You will be hard pressed to find better equipment for the money, and often times for even double the money. For $2,500 you will end up with a home theater on a budget that will make your friend's "home-theater-in-a-box" or expensive "cube" system look like toys.
    Discuss "$2,500 Recommended 5.1 Surround Sound System" here. Read the article.
  2. The Following 2 Users Say Thank You to admin For This Useful Post:
    agarwalro (12-12-2012),zieglj01 (12-12-2012)
  3. #2
    zieglj01's Avatar
    zieglj01 is offline Audioholic Samurai zieglj01 should be listened to
    Join Date
    Aug 2010
    Location
    Texas
    Posts
    2,507
    Thanks Given
    395
    Thanks Received
    746
    Default
    It is nice to know, that my ears are not filled with wax.
    It is nice for someone else to say, that the Pioneers can
    play loud and clean.
    Who and Where - is the Way, the Truth and the Life?
    Speakers > Boston VS 260, Snell K7, Boston E60,
    Pioneer BS22, Cambridge S30 (modified)
    Receiver > Denon 791, Pioneer Elite VSX30
  4. The Following 2 Users Say Thank You to zieglj01 For This Useful Post:
    ahblaza (12-13-2012),monkish54 (12-30-2012)
  5. #3
    agarwalro's Avatar
    agarwalro is offline Audioholic Samurai agarwalro should be listened to
    Join Date
    Jan 2005
    Location
    Central PA
    Posts
    2,711
    Thanks Given
    932
    Thanks Received
    613
    Default
    Huge vote for Andrew Jones and the Pioneer speakers bearing his name.
    A $1000 receiver well drive them just fine and then one won't need the $84 cable, shoot, maybe even a $500 receiver. That opens up budget for an another SB1000 or PB1000.
    Home Office: Behringer 1030A, SVS PB-12 Ultra, measured. Comfy Room: PS3, Sennheiser RS120, Samsung UN46B8500. On the Go: Sansa Clip lost , Etymotic ER-6i commandeered by wife!
  6. The Following User Says Thank You to agarwalro For This Useful Post:
  7. #4
    shadyJ is offline Audioholic General shadyJ is off the scale
    Join Date
    Oct 2006
    Posts
    1,421
    Thanks Given
    101
    Thanks Received
    439
    Default
    I'm know I will rub a few people the wrong way with this post, but there are definitely some poor choices in that list, the chief of which is recommending a pre-processor and separate amp on that budget and with those speakers. My understanding is those speakers would not be difficult load for any receiver. Buying an amp for them is throwing money away. The alternatives suggestions of the Denon and Yamaha receivers are far more logical. Also the article stresses that one of the most common mistakes people make when piecing together a home theater is that they skimp on the subwoofer, and then the article recommends a seriously skimpy subwoofer. None of the alternatives are much better. I would also add that for not much more than the the price of the recommended surge strip, you could get a full fledged UPS from APC or Cyberpower with enough wattage output to protect several major home theater components from a sudden power outage, which is particularly nice to have for any projectors and HTPCs.
  8. The Following 6 Users Say Thank You to shadyJ For This Useful Post:
    3db (12-13-2012),adwilk (12-13-2012),gtpsuper24 (12-13-2012),jcl (12-13-2012),monkish54 (12-13-2012),Sugarbear (12-21-2012)
  9. #5
    zieglj01's Avatar
    Join Date
    Aug 2010
    Location
    Texas
    Posts
    2,507
    Thanks Given
    395
    Thanks Received
    746
    Default
    Quote Originally Posted by shadyJ View Post
    The Pioneers can be driven with a good receiver.
  10. #6
    ImcLoud is offline Audioholic General ImcLoud is considered a mentor
    Join Date
    Aug 2012
    Location
    N.E. CT
    Posts
    1,213
    Thanks Given
    25
    Thanks Received
    360
    Default
    $2500 is a tough budget to recommend a system for... IMO I think the Pioneers {while they are impressive especially for their cost} should be in a much lower budget...
    Like
    Denon 1612 $200
    STF2 sub $329
    With an $80 bluray player, some inexpensive cables, {Blue jeans, mono price, AR, ect} and a mono price surge pro - $78 For only $78.72 each when QTY 50+ purchased - 8 Outlet Home Theatre Power Center w/ Data and Video Protection - 3500 Joules | Home Theater Power Centers
    That would put the budget under $1500 and be a better overall match...
    When spending $2500 I would like to see a better AVR like 709, 1912, ect. with some better speakers like Ascend 340 front with 200 surrounds, WD diamonds, or sale Focals ect... a vtf2 sub and the same blue ray, wires, and mono price surge listed above...
    Now when you step up to $3500 you can get an XPA5 with the umc200 with the ascends, diamonds, ect....
    So not a bad job, and nothing against the pioneers {I like them a lot} but IMO they belong in a $1500- budget not $2500....
    Theater- Emotiva UMC1 pro, ERC2, XPA5 amp, Ascend 340se frnts & cntr, 200se srds, HSU VTF2, PS3, LG 55" LED, & Harmony remote
    Whole house system UPA200 amp, vol. controls, d-box, 6 zones- Yamaha speakers
    Front parlor-2.2 system- XDA1 dac, XPA2 amp, Pure i20 dock, 2 sw300 subs, WD EVO2-40's
    Lwr parlor-2.2 system- Wharfedale Jade 5's, 2 sw300 subs, XPA2
    GYM- EVO2-8's, carver monoblox, wd sub
    bedrm- Jolida 202 tube amp, tekton lores,D1 DAC
    PC-Emo MiniX,CBM170's,12" Sub,D1 DAC
  11. #7
    zman1974's Avatar
    zman1974 is offline Enthusiast zman1974 is gaining some recognition
    Join Date
    Aug 2009
    Location
    Fort Myers, FL
    Posts
    19
    Thanks Given
    1
    Thanks Received
    12
    Default
    You can wall-mount the 22's. You just have to be willing to mount a beefy bracket that allows bigger speakers to be clamped to the mount. I found mine on Amazon thanks to a forum member for $25.00. This mount also allows enough room for the rear port to breath properly.
    Displays: BenQ W5000 FP, 84" Da-Lite Model-C Screen, LG 55LHX LED-LCD, Panasonic 50G10 Plasma Speakers: Pioneer FS52, C22, NHT Superzero 2.0, Rythmik F12 subwoofer Electronics: Pioneer Elite VSX-33 receiver, Oppo BDP-93 Universal Player, Logitech Squeezebox w/ PS Audio Digital Link III DAC, Belkin PureAV and Furman Power Conditioners, Signal and Blue Jeans Cables
  12. The Following User Says Thank You to zman1974 For This Useful Post:
  13. #8
    gene's Avatar
    gene is offline Supreme Audioholics Overlord gene should be listened to
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,818
    Thanks Given
    819
    Thanks Received
    2,401
    Default
    This is a prime example of offering poor advice not based on any personal experience with the equipment in the recommended list. It's easy to sit behind a chair and criticize but it takes far more effort to integrate and test systems which in this case is exactly what we've done. The Pioneer speakers do work well on a $500 A/V receiver, but they also sound better on a good separates solution like the Emotiva. These speakers are good enough to employ better electronics. The SVS sub is NOT a poor performer, its inexpensive and compact and has plenty of output to keep up with the speakers. I am using an EMP ES1010i in this very test system with great results. Corner loading this sub will earn our "medium room" size recommendation. At our GTG show people were very impressed with its output for its size and cost despite it not having tons of output below 30Hz.
    This is a great system for anyone on a modest budget and you would be remiss to judge it without hearing it.
    Gene DellaSala
    President, Audioholics
    Pursuing the truth in audio & video...
  14. The Following User Says Thank You to gene For This Useful Post:
  15. #9
    jcl
    jcl is offline Senior Audioholic jcl is quite helpful
    Join Date
    Sep 2010
    Posts
    581
    Thanks Given
    148
    Thanks Received
    149
    Default
    If you order the UMC200 now you won't get it shipped until I think 1/13. The first two shipments sold out. I didn't see any comments on the Emotiva forums yet. In fact I read one post that said their first impressions thread had been removed. So while Audioholics has done a preview, I think it's still a bit of an unknown quantity. Given how their previous processor launches went I would err on the side of caution and let others venture in first.
  16. The Following User Says Thank You to jcl For This Useful Post:
    AcuDefTechGuy (12-13-2012)
  17. #10
    Join Date
    Oct 2006
    Posts
    1,421
    Thanks Given
    101
    Thanks Received
    439
    Default
    Quote Originally Posted by gene View Post
    This doesn't correspond with my understanding of audio science. Can you explain how those speakers sound better with a separate amp?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
