Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Can I do a 3.1 channel without screwing up the imaging?
  1. #1
    Cristofori's Avatar
    Cristofori is offline Audioholic Cristofori can only hope to improve
    Join Date
    Feb 2010
    Posts
    201
    Thanks Given
    11
    Thanks Received
    3
    Default Can I do a 3.1 channel without screwing up the imaging?
    I would like to have a set up including left, right, center speakers and sub with no surrounds (I don't have the center and sub yet). I don't want to deal with wiring and added costs of surrounds at the moment (possible future upgrade), but I want the benefits of all the rest.
    I have a Marantz SR6006. In the manual it mentions 2.1, 5.1, 6.1 & 7.1 channel set-ups but no '3.1' if that's what you want to call it.
    Will I be able to do this and still use Audyssey without screwing up the imaging? Will the surrounds simply be down mixed into the left and right channels, or will I be losing information during multi-channel playback?
  2. #2
    afterlife2's Avatar
    afterlife2 is online now Audioholic General afterlife2 should be listened to
    Join Date
    Oct 2011
    Location
    In a Small Space.
    Posts
    1,388
    Thanks Given
    518
    Thanks Received
    412
    Default
    I have a 3.1 setup myself and everything works fine for me. I may add another 2 if I can get a deal on the speakers I want. It will not effect anything picture wise.
    Past Onkyo, VizioTV, Pioneer 52s-Klipsch Icon-JBL-Wharf-Outlaw, Sony BD, Denon CD, AudioTek Belt Drive/Technic SL-Q300(Shure M97XE-M104E-AT92ECD-112EP-120E cartS), Onkyo Deck, Sony Minidisc, WDTV, Roku, Sirius, URC R50 & Klipsch iGroove SXT All Destroyed By SandyNOW! Vizio 37"-HK 247-Parasound 1000A-OSD 10" Sub-NXG Pro 4.1-Klipsch-RBH-Cables, Ortofon, Sony CA70ES, Panny DMP-BD87-Sony BX59-Roku XS-Oppo 980-TLS Guy 2.0 Vinyl SetupThankS GentS.
  3. #3
    Cristofori's Avatar
    Join Date
    Feb 2010
    Posts
    201
    Thanks Given
    11
    Thanks Received
    3
    Default
    Quote Originally Posted by afterlife2 View Post
    When I mentioned "imaging" I meant the sound imaging, not video. Sorry for the confusion.
    What I'm concerned with is losing musical information. For example, if you listen to an SACD in multi-channel mode through a two channel amp/receiver, you will lose some sound effects on some recordings. I don't want something similar to happen with a 3.1 set up if the A/V receiver isn't meant to process it that way.
  4. #4
    afterlife2's Avatar
    Join Date
    Oct 2011
    Location
    In a Small Space.
    Posts
    1,388
    Thanks Given
    518
    Thanks Received
    412
    Default
    Quote Originally Posted by Cristofori View Post
    Oh ok then yes you need 5.1 speaker setup then for SACD. I have a couple of them, but since I don't have the 5.1 I can't listen to them yet.
  5. #5
    LB06 is offline Enthusiast LB06 is a forum member in good standing
    Join Date
    Jun 2012
    Posts
    16
    Thanks Given
    0
    Thanks Received
    3
    Default
    It depends on your receiver. If you really can't let it know which speakers you have exactly, but only can say 2.0, 2.1 or 5.1 etc you will lose information, because then you'll have to set it to 5.1 and lose the audio on the rear channels. It won't be downmixed to 3.1 if the receiver doesn't know you have 3.1.
  6. #6
    mtrycrafts's Avatar
    mtrycrafts is offline Audioholic Overlord mtrycrafts should be listened to
    Join Date
    Aug 2004
    Posts
    14,777
    Thanks Given
    142
    Thanks Received
    1,090
    Default
    While the manual doesn't directly come out and say how to do 3.1, page 22 in the manual, step 7, 'detected speakers are displayed' I would think that when you run Audyssey it will detect your 3.1 speakers and display them properly. I would think that when you select this is correct setup, it will do what it needs to do to accommodate this setup.
    But, I would double check with a Marantz support person.
  7. #7
    j_garcia's Avatar
    j_garcia is offline Seriously, I have no life. j_garcia should be listened to
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,285
    Thanks Given
    1,664
    Thanks Received
    3,805
    Default
    Audessey or not, you can simply configure your system to use only the front 3 speakers and you will not lose any information. All of the sound is played from the speakers you have configured. I too currently run a 3.1 setup down from a 5.1 setup and it sounds fine even with SACD. The EFFECT is not the same obviously, but it still sounds good. No sound is lost if the receiver (or source if analog) is configured correctly.
    HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
    System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
    Are you sure which side of the glass you are on?
  8. The Following User Says Thank You to j_garcia For This Useful Post:
    Cristofori (07-08-2012)
  9. #8
    Cristofori's Avatar
    Join Date
    Feb 2010
    Posts
    201
    Thanks Given
    11
    Thanks Received
    3
    Default
    Quote Originally Posted by j_garcia View Post
    Thanks, but can I still use the various surround modes the same as I would with 5.1?
  10. #9
    afterlife2's Avatar
    Join Date
    Oct 2011
    Location
    In a Small Space.
    Posts
    1,388
    Thanks Given
    518
    Thanks Received
    412
    Default
    Yes you won't lose anything, but it will be In Stereo only. To get the full effect of course you need 5.1. You can also use surround sens music which will give you a nice, but fake surround.
  11. #10
    j_garcia's Avatar
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,285
    Thanks Given
    1,664
    Thanks Received
    3,805
    Default
    If you mean the use of things like DPLIIz or some secondary processing like that, yes they will work, but results will obviously vary depending on the mode used. For stereo audio, yes, the processing should still work the same and send all the sound to those speakers just the same. I've run this system and a previous one like this when there was no room for surrounds.
    I don't use any surround modes; aka I let the signal go as whatever it is. The receiver is set to "Auto" and the sources are properly configured to send the signal type that I want so the receiver is decoding what is being sent in its original form (DD+, DTS, etc...) or is only getting analog in the case of my 83SE, which is already processed by that device. For 2ch audio, I leave it 2ch
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
