so our suspect is the XLR cable on the output side to the power amp?
i was not the one who made it, so i will point it out to the person who had that made.
That piece of information pretty well clinches it as being due to external cabling.
From what you say it is likely on the main out wiring on the affected channel.
I would disconnect those first. From your pictures and the online manual, it looks as if you are using the xlr main outs.
If the main outs were shorted then it probably would kill the meter, as they usually get the feed at the end of the chain for obvious reasons.
I would then disconnect any other outputs on the affected channel and use headphones to see which it is. My guess is you have a short somewhere between the main out and the power amp on the affected channel.
This is something that would be easy if you where there, but tricky at long range.
However I would go for the output connections of the affected channel.
I don't see how it could be on the input side.
Marantz DV 9600 Oppo BD-83 Marantz AV 8003 Quad current dumping amps X 7 Direct TV HD 20 HD DVR Carter audio workstation RME Fireface 800 Fujitsu 50XHA40 Front left and right Carter dual transmission line studio monitors MK II. Center Carter coaxial transmission line center speaker Rear Carter NFM-1s Center backs Carter dual transmission line studio monitors MK I. My system: - http://mdcarter.smugmug.com/gallery/...27077317_Pufg7
mike c (03-18-2012)
