Audioholics Home Theater Forums
store.audioholics.com EMPTek.com BlueJeansCable.com Emotiva.com VisualApex.com Yamaha.com/yec SpectraCal.com CEDIA moshimonde.com SVS Sound Subwoofers
Go Back   Audioholics Home Theater Forums > Home Theater Hardware Hangout > GENERAL AV Discussions
Reply
LinkBack Thread Tools Rate Thread Display Modes
  #1
Old 01-28-2012, 07:15 PM
hizzaah is gaining some recognition
Default where's the universal remote love?
I can't imagine everyone is rockin 3+ remotes for their systems. What UR's are you guys using? Suggestions?
I'm looking to pick one up soon, been eyeing the Logitech Harmony series but i'm not sure I want to fork over that much money for one.
I programmed as much as I could into my Onkyo remote but it doesn't support my cable box, and only works 1/2 of the functions of my BR player..
__________________
My College Budget Set-Up
Harmony One
Vizio M370VT
Xbox 360S (modded w/ 250gb HD)
Sony BDP-S480
Onkyo HT-S6300 7.1
  #2
Old 01-29-2012, 08:21 AM
zhimbo's Avatar
zhimbo should be listened tozhimbo should be listened tozhimbo should be listened tozhimbo should be listened tozhimbo should be listened tozhimbo should be listened tozhimbo should be listened tozhimbo should be listened tozhimbo should be listened tozhimbo should be listened tozhimbo should be listened to
Default
There's plenty of Universal remote love; do a search! They don't inflame the passions too much, so they don't take up a lot of forum space, but there's plenty there if you look for it.
I have a mid-range Harmony (the model # is escaping me right now - 700, I think). Yes, initially the price seems high, but I'd just bite the bullet. It's something you use EVERY TIME you use your system, so it quickly seems worth it once you have it.
  #3
Old 01-29-2012, 10:01 AM
Alex2507's Avatar
Alex2507 should be listened toAlex2507 should be listened toAlex2507 should be listened toAlex2507 should be listened toAlex2507 should be listened toAlex2507 should be listened toAlex2507 should be listened toAlex2507 should be listened toAlex2507 should be listened toAlex2507 should be listened toAlex2507 should be listened to
Default
The new URC MX-350 remote
__________________
Harry New Year !!! "Never wrestle with a turd. Win or lose, you still end up with sh!t all over you." -Swerd
"any speaker system in your budget will be an excruciating experience" ~ TLS
I just learned to blare this out of my main system.
  #4
Old 01-29-2012, 10:03 AM
BMXTRIX's Avatar
BMXTRIX should be listened toBMXTRIX should be listened toBMXTRIX should be listened toBMXTRIX should be listened toBMXTRIX should be listened toBMXTRIX should be listened toBMXTRIX should be listened toBMXTRIX should be listened toBMXTRIX should be listened toBMXTRIX should be listened toBMXTRIX should be listened to
Default
I use Crestron control systems in my home and in my installations and they tend to be phenomenal. I simply don't understand why someone will drop $2,000+ on their TV/speaker setup, $100+ a month on cable, and then think spending a couple hundred bucks on a remote which is actually capable of running everything easily is 'expensive'.
The human interface is everything and a good, easy to use remote control, is key to home theater enjoyment for everyone in the family. It's what makes it easy to use and it should be easy to use for your kids, wife, and in-laws/parents just as much as it is easy for you to use.
I typically give people a remote that says 'Cable', 'Blu-ray', 'PS3', 'Wii', and 'Off'. They press one button for what they want to do and the remote handles the rest. Typically using an RF remote so that they don't have to point the remote at something for it to work.
A reliable RF receiver is pricier than a cheap RF receiver, so it costs more, but the nearly 100% reliability of a good remote is well worth it over the course of several years of usage.
With 2 young boys in my home our 4 MX-850 remotes have not had a single failure despite some nearby hardwood floors.
__________________
AV Integrated - Theater, whole house audio, and technology consultation during the build and installation process in the Washington DC, Northern VA, and MD area.
The Following User Says Thank You to BMXTRIX For This Useful Post:
MidnightSensi2 (02-23-2012)
  #5
Old 01-29-2012, 10:04 AM
slipperybidness is gaining some recognition
Default
Look for the Accoustic Research remotes. Cheap as compared to the logitechs and just as good.
  #6
Old 01-29-2012, 10:11 AM
sholling's Avatar
sholling should be listened tosholling should be listened tosholling should be listened tosholling should be listened tosholling should be listened tosholling should be listened tosholling should be listened tosholling should be listened tosholling should be listened tosholling should be listened tosholling should be listened to
Default
I like my Harmony Ones a lot.
__________________
Family Rm: Samsung 52" LCD, Onkyo TX-NR809, Emotiva XPA2 & XPA-3 amps, PS3, Oppo BDP-93, FIOS HD DVR, Salk Song Tower-RT, Song Ctr-RT, Song Surrounds, SVS PB12-Plus/2, Velo SMS-1, NeoTV 550, Roku XS, Harmony-1
Bedroom: Hitachi 42" LCD, FIOS HDTV, Onkyo TX-NR906, LG BD370, NeoTV550, 3x Sierra-1 NrT (LCR), Boston VRX srds, Hsu ULS-15, SMS-1, Harmony-1
Home Office: Onkyo TX-SR707, 2x EMP E41-B, Emotiva Ultra 12 sub, and a small media server
  #7
Old 01-29-2012, 10:33 AM
Lulimet's Avatar
Lulimet is gaining some recognition
Default
I have a Harmony 700. It cost too much and don't even use it much.
I am not impressed with it.
__________________
In metal I trust
  #8
Old 01-30-2012, 07:30 AM
highfigh's Avatar
highfigh should be listened tohighfigh should be listened tohighfigh should be listened tohighfigh should be listened tohighfigh should be listened tohighfigh should be listened tohighfigh should be listened tohighfigh should be listened tohighfigh should be listened tohighfigh should be listened tohighfigh should be listened to
Default
Too much? I just looked online and it's less than $100- you need to see what a properly programmed remote can do.
__________________
Never eat anything that squirts out of a machine.
  #9
Old 01-30-2012, 08:02 AM
AcuDefTechGuy's Avatar
AcuDefTechGuy should be listened toAcuDefTechGuy should be listened toAcuDefTechGuy should be listened toAcuDefTechGuy should be listened toAcuDefTechGuy should be listened toAcuDefTechGuy should be listened toAcuDefTechGuy should be listened toAcuDefTechGuy should be listened toAcuDefTechGuy should be listened toAcuDefTechGuy should be listened toAcuDefTechGuy should be listened to
Default
My two Xoom tablets & my EVO 4G phone are my universal remotes.
They can also remotely turn on and fully control any of my PCs, server, and home thermostat from anywhere in the world with internet access.
__________________
Revel Salon 2 (2) . Linkwitz Orion v3.2.1 (2) . KEF 201/2 (6) . Philharmonic 3 (2) . Funk Audio 18.0 TSAD (2) . Rythmik D15SE (2) . RBH SX-1010N (2) . Denon AVP-A1HD/AVR-5308/AVR-3310 (2)/AVR-3312/4010UD/3800BD . ATI 3005/3002/2004/6012 . Crown XLS2500 (2) . BenQ 6000W (2) . SilverStone CW2 (2) Intel Q9550/Asus P5Q/RAD5750/TT 600W/LG GGC-H20/Cooler MA V8/6TB/8GB . 30TB NAS . Sony S
http://s225.photobucket.com/albums/dd75/AcuDefTechGuy/
http://www.youtube.com/watch?v=-II6pU5vboc
  #10
Old 01-30-2012, 08:31 AM
adk highlander's Avatar
Moderator
adk highlander should be listened toadk highlander should be listened toadk highlander should be listened toadk highlander should be listened toadk highlander should be listened toadk highlander should be listened toadk highlander should be listened toadk highlander should be listened toadk highlander should be listened toadk highlander should be listened toadk highlander should be listened to
Default
I must say I'm a bit of a remote and control system geek. I use all URC products mainly because I have a good dealer that will let me have the software and so far the products are very reliable. I would like to move to a crestron system but getting their software is near impossible unless you are are a dealer and I like to do it all my self.
I use a MSC-400 as the main control unit and it has 2 RF receivers, 6 RS-232 outputs, 6 IR outputs, 6 video/voltage sensors and 2 relays. I have it nearly maxed out now with only 1 relay and 2 ir ports left.
For remotes I have:
MX-980 - Theater,
MX-880 - Master Bedroom
MX-780 - Living Room
KP-900 - House system and out door speakers.
PK-900 - Garage/Workout Space
__________________
Theater Office
Projector: Mitsubishi HC5500 Screen: 84" Severtson tab tension Display: Westinghouse LVM-42W2
PrePro: Marantz AV7005 Amps: ATI AT2002/2005 Universal Player: BDP-83 Media Player: C-200 Server: RAID5 6TB
Mains: Wharfedale EVO2-50 Center: Opus Tri Surrounds: Sonance 623T & SRS1 Subs: Snell ICS-24mk3/LFM-1
Control: URC MSC-400/MX-980 Lighting: Lutron Maestro
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Copyright 2011 AUDIOHOLICS, LLC
