Sorry, forgot to include:
Velodyne VX10 Subwoofer
OK, here's my rundown. I know it isn't anything as nice or fancy as some of y'all have (jealous), but I'm mostly happy with it. I don't have as much space dedicated as I would like (small home), and some of it I collected before I was as gung-ho into HT as I am now. I have other components and gear laying around that I've used or tested in the past, but this is my current configuration for the living area. In the future, I will definitely work on a 2nd (3rd, 4th) setup. My ultimate goal when time, space, money allows would be: 1) A great HT setup that also sounds good for music and 2) A great music setup that also sounds good for movies.
What do you think. Where's the weak link (probably the sub but the towers have built in subs), or the lack of surrounds. Be gentle, or at least take a humorous approach rather than a harsh approach.
52" Samsung 1080p LCD TV (I'll get the model# later, it's about 4 yrs old)
Pioneer Elite VSX-82TXS Reciever
Technics SL1210 MK5 Turntable with Shure M97xE cartridge
TWC Atlanta Scientifice Cable Box / DVR
XBOX 360
PS3
Custom built tower PC, 4gig Ram, Win XP, 1+ TB HDD space, connected to TV with HDMI and to Pioneer with digital coax from onboard HD sound chip from Asus MB (I also have the modem and wired/wireless router hidden here so all connections are hardwired)
Speakers: Goldenear Triton 2 Towers for L/R, and Satellite 50C for the center
Let's say you had this setup and had about $2000 for upgrades or to add components, what direction would you take this setup?
Thanks
Is Goldenear a spinoff of Definitive Technology? I can't believe how much it feels like it is and the nearby billing location (Maryland) is extremely unusual if it is not. Anyway, it seems like you really have a solid setup overall.
Not sure the size of your room, but the subwoofer seems like the most lacking by the specifications. 10" and 100 watts of power. That's the weak point IMO.
There are more than a few suggestions for subwoofers you will get and I will throw in my recommendation for the Epik subs as I like sealed enclosures a lot and think they clean up the bass sound giving punchy accurate, deep bass. A Epik Empire will run a bit under $1,000. A very solid purchase.
From there, not much jumps out at me. If the TV is an older model Samsung LCD, then a new plasma is always nice. Not sure your viewing distance, but at 12' I would go with at LEAST a 59" or larger display. The Samsung PN64 series of plasmas are great. Still, that's a fun upgrade and I would put a good subwoofer ahead of it by a mile.
You aren't exactly hurting overall for decent components, so I really don't have much else which I think you should be upgrading for your setup.
Maybe a really good universal remote?
AV Integrated - Theater, whole house audio, and technology consultation during the build and installation process in the Washington DC, Northern VA, and MD area.
AHA, I forgot the remote: Acoustic Research ARRX15G universal. IMO as good as all but the very top of the line of the Harmony remotes. Probably the best $40 I've put into the setup and great WAF.
Well, Goldenear was started by Sandy (Polk, Def Tech), so that explains a lot. Each tower has built in 1200W amp and 2 subs (appx 5x9 each if I remember correctly), so my poor outboard sub may be a moot point b/c in reality I have 3 subs. My room is large, open floorplan where kitchen/living/entry/dining is all one room+ vaulted ceiling over the living and dining area. A side note: the ribbon tweeters must be heard on these towers.
Yup, I've already been drooling over that Epik Empire, but it's so freaking big. Doesn't bother me, but WAF.
My viewing distance is about 6-7 feet![]()
FirstReflection should be listened to
Huh - I didn't know you were such an Epik fan, BMX
I'm the other side of the coin. I'm not saying it to "knock" Epik or BMX - they're certainly not "bad" subs or anything. But I'm not a fan, and I just like to let people know my honest opinion so that they can make up their own mind. It's really easy to get sucked into the hype, especially if you are already leaning a certain way. Very often, folks are looking for some sort of "consensus" about products. There are a lot of Epik fans, and with good reason. But there are also a number of us who don't think they're "teh greaterest thingz EVAR", so I just say "on the other hand" so as to balance the praise a wee bit
While Epik's current two models are both dual opposed driver designs in sealed cabinets, they don't actually output the natural 2nd order roll off of an unaltered sealed design. Instead, Epik uses an EQ boost in the amplifier to make their subs play flatter down to 20Hz-ish (normally, without the EQ boost, they'd start to roll off up around 40Hz with the gradual 12dB/octave slope). Below that, they put in a filter so that the slope is pretty steep - basically the response sort of mimicks what a natural ported design would deliver with flatter response to a lower frequency, and then a steep roll off below that point.
Absolutely nothing wrong with that design choice! But it's just something to be aware of as you are not getting the natural roll off tendancies of a sealed design is all. The other thing that comes with that design choice is higher distortion. In essence, that EQ is just turning up the volume on the low, below 40Hz stuff. And as you crank up the volume, you get higher distortion as the drivers are forced to move more and the amplifier is dumping more power into them.
Epik gives you a lot for your money, there's no doubt about that! But you also have to be aware that there's no magic going on. They're selling dual driver subs for similar or lower prices than single driver subs. They aren't selling them at a loss. They're using a little bit less expensive drivers so that they can keep the price down. Again, nothing wrong with that - they're choosing a design and aiming for a price point and doing what needs to be done to hit it. But you do get a little bit lower quality drivers just due to the price point. Personally, I've found the end result of all of these design choices is that Epik's subs don't sound quite as "clean" as I would like. They've got a little bit of overhang. A little bit of delay in the transient response. A little bit of audible distortion at loud listening levels.
And I stress here, "a little bit". I'm being very pickyI just personally prefer what some of the competition offers because I tend to favor "tightness" over extension if I have to make that choice. So I personally like the Rythmik FV12 better than the Legend in the $500 price range. And I personally like an SVSound PB12-NSD or HSU VTF-3 MK4 over the Empire in the under $800 price range. But it's a personal preference and I can understand how other people would prefer the Epik subs in those price ranges. Again, I just offer my opinion as a bit of a "counter balance" because otherwise, it's easy to think that "nothing beats an Epik at ANY price", and I just don't think that's the case. They're good subs, I just don't personally think they're "the greatest". I fell into the Epik hype too at one point and wound up disappointed. Not because the Epik subs I bought were "bad". They weren't. But simply because they weren't quite to MY taste. They had a few nit-picks that I think are worth mentioning, so that's all I'm doing
One of the things that happens a lot on message boards is that people are upgrading from a HTiB sub or a really cheap sub to a "proper" sub for the first time. So of course they're absolutely blown away by what an Epik sub sounds like! They've every right to! But in their excitement, they'll also get carried away and praise it a bit too much, and say things like, "I can't even imagine how any other sub could be any better!" You read something like that and it's hard not to get caught up in the hype!
But if you've been in the home theater game a long time and listened and compared a lot of great subwoofers, then you start to realize that even good subs like Epik's can still be improved upon in some areas, and you might even prefer something else in the same price class.
So no knock here. If the Epik subs float your boat, I have no beef with that! They're not MY cup o' tea. And I don't think they're necessarily the very best choice for EVERYBODY. They're the right choice for some folks though. So it's just a matter of matching a person's taste and their room and their associated equipment to the very best match possible. It might be Epik. It might be something else. But just don't get caught up in the hype![]()
walter duque (01-05-2012)
FR - Thanks for the information related to the Epik's... I didn't know that they were doing that with their crossovers.
My first real sub was a Velodyne HGS-10 and now I run a HGS-18 from them. I'm certainly NOT blown away by Epik subs, but I think they sound very good compared to a lot of other stuff I've heard. I installed a couple of Empires and Legends last year and was happy with the results. The point being that there are options, and I really liked reading the AVS Forum shootout of a bunch of different subwoofers. Thought it was one of the best reviews/shootouts I've looked at for a while.
Bottom line, is that there certainly are a number of choices, but overall it is the low end of the system above that seems like the main area that could use improvement. Of course, if the WAF is an issue, then perhaps the money could be used to buy new WAF points.![]()
The subs in those Goldenear towers should knock the crap out of that Velodyne. Theoretically you could spend $2000 on a sub and still not feel it made much difference. If you carefully chose the subwoofer however, the difference could be tremendous.
Buy the wife a gift - and work on the sub replacement.
Who and Where - is the Way, the Truth and the Life?
Speakers > Boston VS 260, Snell K7, Boston E60,
Pioneer BS22, Cambridge S30 (modified)
Receiver > Denon 791, Pioneer Elite VSX30
shadyJ is off the scale
Great turntable, mediocre sub. Don't know about the speakers except they are pretty highly regarded brand.
