Companies still keep offering mono cartridges and many a audiophile keep running to them in spades. Why? What is their draw? Personally, I fel mono sounds flat and unengaging with no spacial cues in music what so ever.![]()
Marantz DV 9600 Oppo BD-83 Marantz AV 8003 Quad current dumping amps X 7 Direct TV HD 20 HD DVR Carter audio workstation RME Fireface 800 Fujitsu 50XHA40 Front left and right Carter dual transmission line studio monitors MK II. Center Carter coaxial transmission line center speaker Rear Carter NFM-1s Center backs Carter dual transmission line studio monitors MK I. My system: - http://mdcarter.smugmug.com/gallery/...27077317_Pufg7
I'm sure someone will come along and explain it to us- I can't wait to read the description of how it makes them all gooey inside and how they're completely recharged, as if they just went on a vacation, just from listening for 1/2 hour.
It must center their chakras, or something.![]()
Never eat anything that squirts out of a machine.
To many rational thoughts run through these forums. I think maybe that question should be asked again on a proper audiophile forum.![]()
AV Integrated - Theater, whole house audio, and technology consultation during the build and installation process in the Washington DC, Northern VA, and MD area.
valvesnvinylfan is quite helpful
Yeah, it’s kind of a fringe thing, but I myself own a true mono cartridge in addition to my stereo cartridges. Why? Because I own and enjoy a ton of classical, jazz, and other pre-stereo, mono era–only records.
A stereo LP's grooves are cut with both horizontal and vertical modulations to produce a signal, while mono LPs contain only horizontal modulations for the signal. However, LPs generally attract dust n dirt into their grooves vertically, and that's where a mono cartridge comes in handy: Since a truly mono cartridge is designed to only pick up the horizontal modulations, using a mono cartridge on a mono record can be much, much quieter in terms of background noise than using a stereo cartridge on same. This is because the mono cart’s generator coil assemblies are 90 degrees/parallel and perpendicular to the record surface instead of 45 degrees/in an X-shaped cross like with a stereo cartridge. Note that a real mono cartridge is different than a cartridge that is just internally strapped for mono; there are an awful lot of cartridges out there whose generators aren’t really “mono-oriented” and their construction is no different than their stereo counterparts: Their two channels are just simply combined before the output pins.
I buy a lot of old, used mono records on the cheap whose grooves have accumulated a lot of gunk, and it seems like no matter how much I clean some of ‘em, some of that gunk is just too deep to get out; having a cartridge that won’t turn a lot of that gunk into noise is a huge blessing when we’re talking about records of solo piano or violin sonatas with quiet passages throughout. And since the mono cartridge I have requires the same alignment/set up parameters as my stereo cartridges, all I have to do is swap one cartridge/headshell combo for another whenever I go from a stereo to a mono record.
So hope this helps explain the mono thing a bit--it's a noise thing (or rather, reduction of). If you enjoy a lot of pre-stereo era records, a mono cart is definitely not required, but it might just make your music a little more enjoyable.
Oliver Amnuayphol
Audio/Home Theater Guru
Aperion Audio
3db (05-20-2011),BMXTRIX (05-19-2011),Cruise Missile (05-19-2011),GranteedEV (05-20-2011),TLS Guy (05-20-2011)
That post just made way to much logical sense. You will need to be taken out back and have your 'vinyl approved audophile' card destroyed!!!
I know, I know, sorry! While I do consider myself somewhat an audiophile, I probably should've peppered my reply with some made up, non-sensical audiophile babble, but unfortunately those just aren't my reasons for owning a mono cartridge![]()
Oliver Amnuayphol
Aperion Audio
Thanks for the explanation. You can tell from what I'm about to say that I may not totally understand your point yet. You are saying that a true mono cartridge playing a mono record has better nosie rejection than a strero catridge playing a stereo record. What my experience has shown me that mono recordings played through a stereo cartrdge are noiser than playing a stereo recoridng through a stereo cartridge. I find teh ticks and pops are more to the forefront of the music. I have not tried a true mono cartrige on a mono LP. Now maybe its teh recording quality wasn't as good as it is now, I'm not sure. Just sharing my experience.![]()
