Da-Lite Screen Company Inc. announced the addition of four VESA (Video Electronics Standards Association) standard mounts to their flat panel monitor mount product offerings. Available as static, tilt or an articulating mount in two lengths, these models will accommodate most flat panels with the VESA standard 75 x 75, 100 x 100, 200 x 200 or 200 x 100 millimeter mounting holes. Each model is load rated up to 40 lbs. and, depending on the monitor's weight, will accommodate monitors up to a 40" diagonal. The tilt model provides 5 degrees of negative tilt (top back) and 20 degrees of positive tilt (top forward). The articulating VESA mount is available with an 11" extension or with a 20" extension. The VESA mounts are finished with a gray or black powder coated finish and offer a five year warranty.
Discuss "Da-Lite Adds Larger VESA Flat Panel Mounts" here. Read the article.
