miggs29 (10-11-2010)
Don't get hung up on the ACD test. Please review my article:Look at the $2700 Yamaha RX-Z7 (140 Watt) as reviewed by HTM (I did not see yours):
http://hometheatermag.com/receivers/...er/index5.html
Quote:
HT Labs Measures
Seven channels driven continuously into 8-ohm loads:
0.1% distortion at 47.1 watts
1% distortion at 54.5 watts
Fortunately, HT content rarely (if ever) makes demands on all channels at the same time, so it may be that your 130watt rated receiver does everything you need.
However, look at the equivalent specification from Audioholics review of the UPA-7 (125 Watt):
http://www.audioholics.com/reviews/a...7-measurements
7 channels into 8 ohms 1kHz powersweep:
0.1% distortion at 108 watts
1% distortion at 117 watts
So if the above Yamaha power rating trends are consistent with your specific receiver, it is safe to assume the UPA has more power than your Yamaha has to offer.
However, I would not recommend that you replace your Yamaha amp section entirely, but, rather that you split duties between them.
By only running 2 or 3 channels off of he Emotiva and the balance off of the Yamaha, you will have loads of dynamic headroom if and when you need it.
Edit/Delete Message
The All Channels Driven Amplifier Test
The amp section in the RX-Z7 is quite capable as I have it powering my family room system which 3 of the 7 speakers are 4 ohm rated and I never feel power started.
Also read my RX-Z7 Review and you will see its got some good juice:
tsand is a forum member in good standing
I purchased the XPA-2 and use an old 3802 Denon for the sub, center, rear r/l and center.
I am saving up my pesos for an XPA-5 to replace the Denon for amplification and a UMC-1 for the processing.
PS the UPA-5 (125w/channel at 8 ohms) is on sale for $399 for Halloween. The XPA-5 is 200w/channel at 8 ohms but is double the price.
Have fun!
Pyrrho should be listened to
Unless you are noticing distortion at high volumes, I would not bother with a power amp. Power that you don't need does nothing for you, so only buy it if you need it, unless you like wasting your money on things that give you no improvement in actual sound. In which case, you might as well send it to me, and I will make no improvement in your sound.
__________________
A fool and his money are soon parted.
__________________
Too many people seem to spend too much time reading between the lines for what is not there instead of paying attention to what is there.
miggs29 is a forum member in good standing
Well, now the XPA-3 is on sale with free shipping. $529. Hmmm
http://emotiva.com/xpa3.shtm
Samsung LNT5271F
Yamaha RX-V1700
Emotiva XPA-3
Panasonic DMP-BD85K
Harmony 900
EMP Impression E55Ti
EMP Impression E5Ci
EMP Impression E5Ti
Klipsch Synergy Sub-10
What cables do I need to hook up the EMO XPA-3 to a Yamaha RX-V1700 other than 3 RCA cables? What kind of cable do I need for the trigger connection on the back of the XPA-3? Do you recommend using the trigger connection?
Which of these cables do I need?
http://emotiva.com/shop/cart.php?m=product_detail&p=75
http://emotiva.com/shop/cart.php?m=product_detail&p=65
What is the difference between the two?
Samsung LNT5271F
Yamaha RX-V1700
Emotiva XPA-3
Panasonic DMP-BD85K
Harmony 900
EMP Impression E5Ci
EMP Impression E5Ti
Family Rm: Samsung 52" LCD, Onkyo TX-NR809, Emotiva XPA2 & XPA-3 amps, PS3, Oppo BDP-93, FIOS HD DVR, Salk Song Tower-RT, Song Ctr-RT, Song Surrounds, SVS PB12-Plus/2, Velo SMS-1, NeoTV 550, Roku 3, Harmony-1
Bedroom: Hitachi 42" LCD, FIOS HDTV, Onkyo TX-NR906, LG BD370, NeoTV550, 3x Sierra-1 NrT (LCR), Boston VRX srds, Hsu ULS-15, SMS-1, Harmony-1
Home Office: Onkyo TX-SR707, 2x EMP E41-B, Emotiva Ultra 12 sub, and a small media server
That's correct for moving the audo. If it's specifically 3 channel, I'd grab one of my component-video cables and use that (three RCA cables conveniently bundled and color-coded).
I picked up several when the local hhgregg was selling them for $4 each.
I *think* it's any standard 1/8" connector.What kind of cable do I need for the trigger connection on the back of the XPA-3? Do you recommend using the trigger connection?
Sound First! *
(* Women first, sound second, food third)
KEW should be listened to
