Sure, others might have your display, but we're betting you don't know anyone with a motorized mount. The Sanus Systems VLMF109 motorized mount accommodates displays from 37" to 56" an up to 110lbs. It can be laterally shifted for installation on off-axis studs, sits as close as 2" off the wall and can extend to 9" with a 60 degree swivel. It is IR controlled and has two presets for integration into universal remote setups. You may not need a motorized mount, but you know you want it.
Discuss "Sanus VLMF109 Motorized Flat Panel Mount First Look" here. Read the article.
