Results 1 to 6 of 6
Thread: Sanus NF Series NFA-245 Audio Stand Review
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Sanus NF Series NFA-245 Audio Stand Review
    Face it, when people call you to talk about their great home theater or 2-channel audio room they just set up, they rarely tell you about the piece of furniture they store all their gear on. In fact, most of the rooms I help folks set up use either an old piece of furniture or some other make-shift AV stand and sink all their AV budget into their gear. While I certainly understand wanting to get the best gear for your money, I have found that having a high quality AV stand to store your gear in can be the finishing touch that takes the room from the "man room in the basement" to the family theater that you or your spouse will be proud to include on the home tour next time guests are over. Not to mention that stands like the NFA245 are designed to not only look great, but to also help ensure that gear is in optimum operating conditions that will prolong the life of your equipment and improve its performance.
    Discuss "Sanus NF Series NFA-245 Audio Stand Review" here. Read the article.
  2. #2
    davidtwotrees's Avatar
    davidtwotrees is offline Audioholic General davidtwotrees should be listened to
    Join Date
    Oct 2006
    Location
    Wheaton, IL suburb of Chicago
    Posts
    1,157
    Thanks Given
    183
    Thanks Received
    191
    Default
    I've owned this exact rack for a number of years, and the reviewer was spot on. It is an excellent addition to my home theatre rig, and has seen dozens of pieces of gear go in and out of the system. It is solidly built, graceful, and attractive. It has had a couple of amps that weighed in excess of 60 pounds on it. I found the cable management holes to be just fine, and only when the analog sacd bundle goes through does one of them become tight with wiring. I have the black satin finish and it looks sharp with black gear, and my silver lacquer Canton speakers. I bought mine open box for under $250. D2T
    Quad 12L Active,Aperion 8A Sub, LexiconDC1,Samsung BDP2550,Escient SE80,Panasonic42PX,ParasoundHCA1000 for zone 2
  3. #3
    cwall99's Avatar
    cwall99 is offline Full Audioholic cwall99 is off the scale
    Join Date
    Dec 2007
    Posts
    312
    Thanks Given
    10
    Thanks Received
    43
    Default I have this one too...
    ... I just got mine about five or six weeks ago, and, like the previous poster said, it is a breeze to put together. I did pretty well with the interconnects through the holes, though, as I started to get close to the end of the process, the holes going into the back of the shelf where my receiver is, were getting pretty full.
    It does sway slightly, especially if I'm standing there, pressing buttons on my receiver (a Pioneer VSX-82TXS - or whatever). It's on the second to top shelf (I wanted a tall stand so I could finally put my turntable out and not worry about my two-year old daughter playing with it).
    But, with that heavy load of the turntable up high, and no real counter-weights at the bottom, it does feel a little top heavy.
    I think it could be an inch or so deeper, too, to give you a bit more room in back to plug in banana plugs and interconnects. Some of mine have to make a pretty severe Z between the holes in the back piece and the places where they plug into my receiver.
    Casters would have been nice as I had to do most of my connections with the receiver about a foot further out from where it now sits, but I know that would have added to the stability issue.
    Still, it's good looking, and the top shelf lines up perfectly with the top of my old-ish (fall, 2002) Sony 57-inch RPTV.
    Best part? I only paid about $200, with about $45 shipping, for mine. I ordered it on Wednesday, and it was sitting by my back door that Friday (and that was after the shipping method I elected to use promised an 8 to 12 business day turnaround).
    Nice rack. Not perfect, but in this economy, I'm not complaining.
    I guess, though, to stabilize the weight issue, what I really ought to do is buy a bunch of massive amps, put them on the bottom shelves, and then use my receiver as a pre-amp. I'm sure my wife would go for that.
    Pioneer Elite VSX-82TXS, Pioneer Elite BDP-62FD, B&W 603 s3, B&W LCR 600, NHT 1.3A, Panasonic Viera TC-P50G20, Earthquake Super Nova MKV-15
  4. #4
    cwall99's Avatar
    Join Date
    Dec 2007
    Posts
    312
    Thanks Given
    10
    Thanks Received
    43
    Default Sorry, I lied...
    ... I have the NF206, not the NFA 245.
    Still, the review pretty much applies exactly to my stand, too.
    Okay, it wasn't a lie. I just got excited to almost see my rack reviewed right here at the center of the AV universe.
  5. #5
    Dezoris is offline Audioholic Dezoris is gaining some recognition
    Join Date
    Sep 2005
    Posts
    188
    Thanks Given
    5
    Thanks Received
    12
    Default
    Gary!
    Where are the pictures?
    The stock photo blows and all I can see is a foot, and parts of the back of the unit on the pictures attached.
    Yamaha RXV3800 - Oppo HD981 - Panasonic AE2000 - Optoma H31 - Definitive Technology 7.1 - BluRay
  6. #6
    Soundman's Avatar
    Soundman is offline Audioholic General Soundman is considered a mentor
    Join Date
    Jun 2007
    Location
    Dortches, NC
    Posts
    1,436
    Thanks Given
    106
    Thanks Received
    143
    Default
    Quote Originally Posted by Dezoris View Post
    Gary!
    Yeah, Anyone have a better picture of this thing?
    HT
    Pre/pro- Emotiva LMC-1/LPA-1 Sources- Panasonic DMP-BDT220, Nintendo Wii, PS3 80g with Samsung M6 Series HM320JI 320GB HDD Display- Mitsubishi WD-65736 Speakers-Rocket RS850 Signature (mains), Rocket RSC 200 Signature (center), Rocket RS450's (surrounds) Sub- PB-13 Ultra Other- APC 350, Newpoint 204220 Wires/Interconnects- Monoprice
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
