Page 5 of 52 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 511
Thread: Vinyl News
  1. #41
    WmAx's Avatar
    WmAx is offline Audioholic Samurai WmAx should be listened to
    Join Date
    Apr 2004
    Posts
    5,177
    Thanks Given
    3
    Thanks Received
    1,353
    Default
    Quote Originally Posted by 3db View Post
    WMAX..Any thoughts on this? I guess its a good platform for evaluating cartridges and tonearms.
    http://news.cnet.com/8301-17938_105-10067309-1.html
    http://www.insidebayarea.com/ci_1067...e=most_emailed
    Well, it would be nice to have a multi-mount table for arm evaluation. But for accurate arm evaluation, one would needs to use the same cartridge one each arm(and adjust arm mass with add on mass if needed to get an similar arm mass/cartridge compliance resonant frequency for each compared set) and record the same tracks into an ADC, then synch/level match the recordings and evaluate with ABX software. These last steps are rarely performed, and most evaluations are next to worthless sighted ones.
    That table seems way over priced. While you do need to spend considerably more to get a high quality mechanical system as compared to a digital/electronic device, I wager there are still points where in excess you are wasting your money compared to a wise lower priced purchase. I think that one can assembly a near perfect turntable system(system meaning turntable, motor and tone arm) for $1500-$2000 range with careful selection and that spending more will probably be a waste of money.
    -Chris
    Dedicated to improving the real[quantifiable] parameters of sound reproduction.
  2. #42
    3db's Avatar
    3db
    3db is offline Audioholic Spartan 3db should be listened to
    Join Date
    Sep 2002
    Posts
    7,326
    Thanks Given
    1,330
    Thanks Received
    1,385
  3. #43
    3db's Avatar
    3db
    Join Date
    Sep 2002
    Posts
    7,326
    Thanks Given
    1,330
    Thanks Received
    1,385
    Default update
    more numbers on vinyl growth
    http://www.lsureveille.com/1.897564
  4. #44
    WmAx's Avatar
    Join Date
    Apr 2004
    Posts
    5,177
    Thanks Given
    3
    Thanks Received
    1,353
    Default
    I am very curious about the SQ of this new Guns N' Roses album. Axle Rose has been so insanely OCD about the music being perfect.... that it has been in production for over a decade or so..... but does his OCD end at only the music.... allowing the same crap excuse for a recording to be released as most other bands do today?
    -Chris
  5. #45
    3db's Avatar
    3db
    Join Date
    Sep 2002
    Posts
    7,326
    Thanks Given
    1,330
    Thanks Received
    1,385
    Default
    Quote Originally Posted by WmAx View Post
    -Chris
    I can't answer that question. I guess we'll need to find a guinee pig to purchase it and give us their impression..
    OPn another note, do you have Queen's 1st album on vinyl? If so what do you think of its recording quality?
  6. #46
    jliedeka's Avatar
    jliedeka is offline Audioholic Chief jliedeka should be listened to
    Join Date
    Aug 2007
    Location
    Madison, Wisconsin
    Posts
    982
    Thanks Given
    222
    Thanks Received
    246
    Default
    I just got Metallica's Death Magnetic on vinyl. It's pretty good. I've heard it's not as obnoxiously compressed as the CD. Since I haven't heard the CD, I can't comment. It's metal so of course it's compressed.
    Jim
    I did not look at any tube preamps for the same reason that Car and Driver is not reporting on buggy whips. - David A. Rich, PhD
    The audiophile reviewer will pick the most warped sound as his reference for sonic purity. - GranteedEV
    Receiver: Marantz SR8002 Speakers: Paradigm Studio 20, Studio CC-490, Studio 10 Subwoofer: HSU VTF-3 Mk3 Sources: Oppo BDP-93, Xbox360 TV: Panasonic TC-P50V10
  7. #47
    3db's Avatar
    3db
    Join Date
    Sep 2002
    Posts
    7,326
    Thanks Given
    1,330
    Thanks Received
    1,385
  8. #48
    3db's Avatar
    3db
    Join Date
    Sep 2002
    Posts
    7,326
    Thanks Given
    1,330
    Thanks Received
    1,385
    Default Tom Petty solving the CD compression problem
  9. #49
    3db's Avatar
    3db
    Join Date
    Sep 2002
    Posts
    7,326
    Thanks Given
    1,330
    Thanks Received
    1,385
  10. #50
    WmAx's Avatar
    Join Date
    Apr 2004
    Posts
    5,177
    Thanks Given
    3
    Thanks Received
    1,353
    Default
    For some reason AH has banned the site. ???
    Anyways, for those that want to read it, it's:
    www[dot]audaud[dot]com/article.php?ArticleID=5148
    The reviewer considers an almost 2k table to be 'entry level' - ?? I guess one must spend 50-100K for one of those super exotic tables to have an 'actual' high end/high performance table? LOL
    -Chris
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
