Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: On Location: Denon Line Show 2008
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow On Location: Denon Line Show 2008
    This week I had the privilege of attending the Denon Line Show & Press Event in Dana Point, California. A top floor room that looked out over the Pacific Ocean from the Laguna Cliffs Marriott Resort & Spa was my home for a couple of nights while attending, and it proved to be a great trip full of demos and information. An idyllic setting by any measure, and it provided me a great evening of relaxation prior to my day of work - yeah, we call this work.
    Discuss "Editorial: Denon Line Show 2008" here. Read the article.
  2. #2
    mike c's Avatar
    mike c is online now Audioholic Warlord mike c should be listened to
    Join Date
    Jul 2005
    Location
    behind you
    Posts
    9,239
    Thanks Given
    1,560
    Thanks Received
    1,950
    Default
    can we get a full spec of the 2809? what it has over the old 3808?
  3. #3
    mudrummer99 is offline Senior Audioholic mudrummer99 is considered a mentor
    Join Date
    Jan 2008
    Posts
    545
    Thanks Given
    110
    Thanks Received
    97
    Default
    When did they make you a Mod Mike? Grats on that
    Mike
    My HT:Sony 40" LCD / Pioneer Elite SC-05 / PS3 / Klipsch F-3 Mains / Klipsch Icon VC24 center / Martin Logan Dynamo / Pioneer Elite DV-48AV / Harmony One w/ PS3 adapter
    My "Office": 23" Samsung LED ws monitor / 19" Samsung montior/TV / Homebuilt computer / Yamaha DV-S5750 / Yamaha HTR-5840 / Klipsch B-3 fronts and quintet surround set
    "My HT is like the Genie, enormous cosmic power, itty-bitty living space"
  4. #4
    mike c's Avatar
    Join Date
    Jul 2005
    Location
    behind you
    Posts
    9,239
    Thanks Given
    1,560
    Thanks Received
    1,950
    Default
    Quote Originally Posted by mudrummer99 View Post
    Mike
    thanks. just the other day.
  5. #5
    MapleSyrup's Avatar
    MapleSyrup is offline Audioholic MapleSyrup is quite helpful
    Join Date
    Sep 2007
    Posts
    200
    Thanks Given
    6
    Thanks Received
    14
    Default Upgrades
    I recently upgraded from Denon to Onkyo...and now dennon pulls a sweet stunt like this and demos sweet new gear? Tis a curse and a blessing I guess.
  6. #6
    tn001d's Avatar
    tn001d is offline Senior Audioholic tn001d has a small fan club
    Join Date
    Apr 2007
    Location
    Cleveland , Ohio
    Posts
    562
    Thanks Given
    27
    Thanks Received
    42
    Default
    Quote Originally Posted by MapleSyrup View Post
    I think you meant downgraded
    HD Theater: Mitsubishi WD-65908 (Calibrated), Denon DVD-3800BDCI, Toshiba HD-XA2, Denon AVR-2807, Scientific Atlanta 8300 HD-DVR, Sony SCD-2000ES, Paradigm 6.1 System, SVS PB10-ISD, Monster Signature HTS7000MKII, Monster HTS-5100MKII
    Digital Theater : Sony 40inch 1080P 120Hz LCD TV, Denon AVR-2809CI, Paradigm 5.1 System, SVS PB10-NSD, Sony BDP-S550, Toshiba HD-A35, Scientific Atlanta 8300 HD-DVR, Sony 5 Disc CD, Sony Dual Cassette Deck, Teac Dual CD Recorder, Monster HTS-3600MKII
  7. #7
    mike c's Avatar
    Join Date
    Jul 2005
    Location
    behind you
    Posts
    9,239
    Thanks Given
    1,560
    Thanks Received
    1,950
    Default
    oh, Mr. Clarke, and while you are there ...
    ask them if this new audyssey thingy won't kill the "exciting" peaks in soundtracks.
    i mean, explosions do come suddenly and in between quiet passages a lot
  8. #8
    Seth=L's Avatar
    Seth=L is offline Audioholic Overlord Seth=L should be listened to
    Join Date
    Sep 2006
    Posts
    12,034
    Thanks Given
    1,204
    Thanks Received
    1,652
    Default
    OK, OK, OK!!!!
    The Denon DVD-1800BD, it looks somehow familier to me. Note how the upper end Blu-ray players that Denon sells currently don't have a nifty little SD card slot on the bottom right corner of the unit. Also note the location of the display and the stop/play/pause/eject buttons. It would be remarkably simple to configure the play/pause/stop buttons to another function (making it appear to be different from OEM). The power button is on the far left, instead of where it would be on the OEM (on the far right). The remote sensor is in the same location on the Denon as the OEM, but you can't tell from pictures (I have seen the OEM up close). The Denon seems to have the same physique as the OEM, which isn't the least bit surprising.
    The Denon is profile 1.1, features HDMI 1.3 (bitstreams DTS-HD and Dolby TrueHD, stereo analog audio output, no internal processing for DTS-HD and Dolby TrueHD.
    Enter the OEM, a Funai (which has made OEM video products for Denon in the past), it features profile 1.1, HDMI 1.3 (bitstreams DTS-HD and Dolby TrueHD, stereo analog audio output, no internal processing for DTS-HD and Dolby TrueHD. The Funai makes up a Philips Blu-ray player, a Magnavox Blu-ray player, a Sylvania Blu-ray player, and reportedly an Insignia Blu-ray player.
    Now this comes as no surprise, it's just disappointing to catch companies like Denon playing so dirty. I guess if the Funai is alright for Denon, then the sub $300 Magnavox is alright for Joe Six pack.
    http://www.audioholics.com/news/on-l...0816.jpg/image
    vs.
    http://www.avsforum.com/avs-vb/showp...5&postcount=51
    http://www.avsforum.com/avs-vb/showp...1&postcount=52
    http://www.avsforum.com/avs-vb/showp...2&postcount=53
    http://www.avsforum.com/avs-vb/showp...6&postcount=54
    http://www.avsforum.com/avs-vb/showp...3&postcount=55
    To anyone that buys the Denon, be sure to pop the hood on that guy and see how it compares to the Magnavox pictured in the links above.
    I just realized, this is controversial.
  9. The Following 2 Users Say Thank You to Seth=L For This Useful Post:
    mike c (05-23-2008),tn001d (05-23-2008)
  10. #9
    tn001d's Avatar
    Join Date
    Apr 2007
    Location
    Cleveland , Ohio
    Posts
    562
    Thanks Given
    27
    Thanks Received
    42
    Default
    Honestly when i saw this new denon blu-ray player i knew it was going to be crap.. I am not surprised to find out its a funai/magnobox/phoolips underneath
    Personally it comes down to the Sony BDP-S550 or the Pioneer BD-51FD (pseudo elite) blu-ray players.
    Is it me or is denon's face plates not as shiny black as they used to be and has more of flat (blah) look to it now.
  11. #10
    AVRat's Avatar
    AVRat is offline Audioholic Ninja AVRat should be listened to
    Join Date
    Jun 2005
    Location
    Colorado Springs, CO
    Posts
    3,790
    Thanks Given
    353
    Thanks Received
    680
    Unhappy Aaaaaargh!!!!!
    This sux!! Still no word on a Pre/pro for Joe Microbrew! Marantz’s AV-8003 pre/pro seems a little lacking in features to compete with the Onkyo/Integra pre/pros.
    Mitsubishi LaserVue L75-A91, Denon AVR-4810CI, Oppo BDP-83, Escient FireBall MX-111, APC H15
    Speakers: L/R - ESS AMT Monitor, Def Tech ProCenter C2, UIW BP In-wall, UIW 64 In-ceiling, Dual SVS PB12-PLUS, Def Tech SuperCube I
    Zone 2 (3 Areas through Niles HUB8, Niles MSU-480, Niles TS-110 Table Top Sensor & 3 x Niles IM/VC w/IR sensor)
    Paradigm CS60R In-ceiling 2 Pair
    Exterior -- Backyard Patio
    Paradigm Stylus 250
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
