Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: 3.1 vs. 5.1 - which one?
  1. #1
    phillyrx is offline Audioholic Intern phillyrx is a forum member in good standing
    Join Date
    Nov 2007
    Posts
    33
    Thanks Given
    3
    Thanks Received
    0
    Default 3.1 vs. 5.1 - which one?
    so everytime i want to pull the trigger on a 5.1, i debate whether or not i should just get a 3.1. reasons for doing so are: looks neater (speakers not everywhere), no wires to worry about, and possibly less cost.
    i have been currently living off the audio from my aquos 46' tv, and haven't had too much of an issue, but would like better sound. so i don't need an amazing system or whatnot, just something to give an upgraded sound from just tv audio.
    i still have a budget of $560ish for the system to pair with my onkyo 605 receiver. so my question is, do you think its possible that i'd be happy with a 3.1 system considering that i'm kinda okay with just the tv audio alone? also, any good 3.1 setups you recommend (want better than htib sound, but nothing crazy)? also, size is important so bookshelves would be preferable. i CANNOT have floorstanding speakers... i'm okay with the bigger (10") sub though
    if it helps... 99% of use will be for watching movies, tv, and playing wii... very little on music alone...
    thanks so much, and i apologize for all the questions!
  2. #2
    mazersteven's Avatar
    mazersteven is offline Audioholic Spartan mazersteven should be listened to
    Join Date
    Mar 2005
    Location
    Florida
    Posts
    6,028
    Thanks Given
    1,138
    Thanks Received
    1,343
    Default
    How long will it take you to save another $400 bucks if you want 5.1?
    SVS SBS-01
    http://www.svsound.com/products-sys-sbs_black.cfm
    Or if not. I recommend getting
    SVS SBS-01 Pair - Black $225
    SVS SCS-01 Center - Black $185
    http://www.svsound.com/products-spks-sbs01.cfm
    plus this sub
    Dayton SUB-120 12" 150 Watt Powered Subwoofer $148
    http://www.partsexpress.com/pe/showd...number=300-635
    Total is $558 plus shipping.
  3. #3
    AcuDefTechGuy's Avatar
    AcuDefTechGuy is online now Audioholic Overlord AcuDefTechGuy should be listened to
    Join Date
    Jul 2007
    Location
    Krypton
    Posts
    13,563
    Thanks Given
    3,375
    Thanks Received
    3,025
    Default
    I say just get this $400/pr Tower from AV123 for now:
    http://av123.com/index.php?page=shop...mart&Itemid=37
    Then when you get more money, get a $430 SVS sub:
    http://www.svsound.com/products-sub-box-10nsd.cfm
    Then when you get more budget, get a $200 AV123 Center speaker:
    Then later $300/pr surround speakers:
    REVEL SALON2 . B&W 802D2 . KEF 201/2 (6) . LINKWITZ ORION3 . TAD 2201 . DYNAUDIO X32 . FOCAL 826V . ATC SCM7 . PHILHARMONIC 3 . FUNK 18.0 (2) . RBH SX-1010N (2) . VELODYNE SC600 (4) . PIONEER MM301 (8) . DENON AVP-A1HD/AVR-5308/AVR-3312/DVD-3800BD . ATI 3005/3002/2004/6012 . BENQ W6000 . ADCOM GFS-600 . APPLE TV . KIMBER KABLE 8PR
    My System Photo . My System Video
  4. #4
    j_garcia's Avatar
    j_garcia is offline Seriously, I have no life. j_garcia should be listened to
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,285
    Thanks Given
    1,664
    Thanks Received
    3,805
    Default
    I agree with going 3.1 at first and adding the others later as budget permits. It is a better path long term IMO.
    HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
    System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
    Are you sure which side of the glass you are on?
  5. #5
    aberkowitz's Avatar
    aberkowitz is offline Audioholic Field Marshall aberkowitz should be listened to
    Join Date
    Sep 2007
    Location
    Hoboken, NJ
    Posts
    1,757
    Thanks Given
    380
    Thanks Received
    464
    Default
    I would say that even 2.1 is a good temporary solution. I lived with 2.1 for several years when I had roommates and had my "home theater" setup in my bedroom. I found that having the sub was a better investment (for both movies and music) than the center channel.
    Living Room Setup: Yamaha RX-A1010BL, Samsung PN59D6500D, Infinity TSS-SAT4000 x2, Infinity TSS-CENTER4000, Infinity SAT 1100 x2, Infinity TSS-Sub-4000 12", 120 GB PS3, Oppo DV-981HD, Wii, Logitech Harmony One, Roku (For the bedroom)
  6. #6
    rnatalli is offline Audioholic Ninja rnatalli should be listened to
    Join Date
    Jul 2007
    Posts
    3,245
    Thanks Given
    377
    Thanks Received
    678
    Default
    Yup, 2.1 or 3.1 and upgrade later.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    -Benjamin Franklin
  7. #7
    Join Date
    Nov 2007
    Posts
    33
    Thanks Given
    3
    Thanks Received
    0
    Default
    Quote Originally Posted by mazersteven View Post
    SVS SBS-01
    plus this sub
    thanks for the response mazer! i think i'm leaning the 3.1 rute for now also. the one thing i seem to hear is to spend a good chunk on the sub. in your option, you have most going to the fronts. in your opinion, or anyone for that matter, which is most important? thanks!
  8. #8
    Join Date
    Nov 2007
    Posts
    33
    Thanks Given
    3
    Thanks Received
    0
    Default
    Quote Originally Posted by AcuDefTechGuy View Post
    acudeftechguy - as much as i'd like to do that... we have so many home improvments, that my budget for a home theatre is gonna be in the $560ish range for a couple of years. given that, i'd like to get at least a 3.1 for that price. i understand this won't be ideal, but i can easily live with that... thanks for the help!
  9. #9
    Join Date
    Mar 2005
    Location
    Florida
    Posts
    6,028
    Thanks Given
    1,138
    Thanks Received
    1,343
    Default
    Quote Originally Posted by phillyrx View Post
    IMO I recommended the best system for sound quality for your budget. Your fronts are the main speakers for any system.
  10. #10
    Join Date
    Nov 2007
    Posts
    33
    Thanks Given
    3
    Thanks Received
    0
    Default
    any thoughts on the svs you recommend vs. psb alphas that i hear so much about?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
