Results 1 to 3 of 3
Thread: Sony HT-DDW790 Home Theater System
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Sony HT-DDW790 Home Theater System
    Sony is typically known for their higher end consumer electronics, at least that's what the big box salesman will tell you as he shows you the price. This is certainly true sometimes, but let it be known that Sony can make entry level products with prices to match. Enter the HT-DDW790, a very low cost 5.1 home theater system. This unit is very basic and comes with a full size receiver that has only a few inputs, 6 speakers with wire, and a remote control.
    Discuss "Sony HT-DDW790 Home Theater System" here. Read the article.
  2. The Following User Says Thank You to admin For This Useful Post:
    Phil Taylor (01-03-2008)
  3. #2
    allargon's Avatar
    allargon is offline Audioholic General allargon should be listened to
    Join Date
    Jun 2007
    Location
    Austin, TX
    Posts
    1,129
    Thanks Given
    145
    Thanks Received
    185
    Default
    I own one of these. I paid a LOT less than the MSRP quoted in the article.
    The sound of it is slightly better than one of those console (non-portable) boomboxes. It has no banana clips--only spring loaded pressure clips for that what? 24 gauge speaker wire. The receiver does accept full bit-rate DTS over coax and toslink. This is an issue for people w/ 2nd generation HD-DVD players, since the players convert high res audio to DTS. The tuner? It's a tuner. Stations come in clearly. It is fine for movies and (just) okay for TV. The auto calibration isn't great. However, Tom and Dina would tell me to stop listening to their podcasts and use a SPL to get it right. (Yes, I listen.)
    It's not a horrible system. I wasn't too happy listening to classical or jazz with it. However, I heard all the bass via the Transformers HD-DVD without issues.
    My major complaint is its size and that it only comes in silver!
  4. The Following User Says Thank You to allargon For This Useful Post:
  5. #3
    Phil Taylor's Avatar
    Phil Taylor is offline Senior Audioholic Phil Taylor is looking for a job at AH
    Join Date
    Jan 2006
    Location
    OKC, OK USA
    Posts
    745
    Thanks Given
    175
    Thanks Received
    195
    Default
    How much is "a lot less than MSRP"? This one may enter the "consider list" for my 5 year-old son's room. It's stated it has a passive sub - how much is the power output for the sub? BTW - Transformers is currently his favorite movie.
    Certifiable Home Theater Systems Nut
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
