Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: HDMI Connections and Interface - A Beginner's Guide
  1. #1
    Clint DeBoer's Avatar
    Clint DeBoer is offline Administrator Clint DeBoer should be listened to
    Join Date
    Jul 2002
    Location
    Lakeland, Florida, United States
    Posts
    6,153
    Thanks Given
    509
    Thanks Received
    805
    Default HDMI Connections and Interface - A Beginner's Guide
    audioholics.com/education/display-formats-technology/hdmi-interface-a-beginners-guide">[HDMI_female]Starting around 2003 we saw a rapid adoption of the Digital Visual Interface (DVI) across the digital consumer market. This included DTVs, high definition set –top boxes and computer graphics boards. By the end of that year, well over 500 consumer electronics products featured a DVI connection, with approximately 80% of DTVs shipped to the US using that technology. Later in the year, HDMI also emerged as a digital transmission format, but addressed some specific needs tailored to the consumer electronics market. Read on to learn everything there is to know about HDMI.
    [Read About HDMI]
    Clint DeBoer
    Editor in Chief
    Audioholics
  2. #2
    racquetman's Avatar
    racquetman is offline Audioholic Chief racquetman should be listened to
    Join Date
    Jun 2005
    Location
    Norton Shores, MI
    Posts
    850
    Thanks Given
    1
    Thanks Received
    19
    Default Beginner's guide??!!
    If that's the beginner's guide, people's heads are going to explode when you post the expert guide
  3. #3
    Join Date
    Jul 2002
    Location
    Posts
    6,153
    Thanks Given
    509
    Thanks Received
    805
    Default
    Haha, well its written a bit for both I suppose.
    It covers much of the spec while interjecting explanations in more simplified language for much of the important stuff. We've been talking with people at HDMI.org and wanted to make some of the aspects and capabilities of the relatively new format available so readers could understand why it's such a big deal.
    The Consumer Electronics Control (CEC) features are especially impressive and should really revolutionize home theater systems once effectively implemented.
    Clint DeBoer
    Editor in Chief
    Audioholics
  4. #4
    HookedOnSound's Avatar
    HookedOnSound is offline Full Audioholic HookedOnSound has a small fan club
    Join Date
    Oct 2003
    Location
    ON, Canada
    Posts
    343
    Thanks Given
    3
    Thanks Received
    0
    Default keeping it simple
    Thanks for posting the guide,
    I myself can't wait until all connections are the same (HDMI), imaging the real estate retrieved in the back of receivers!
    I have never been satisfied with the spacing for speaker posts/terminals (I got big/clumsy hands), I have gone with banana plugs strictly for ease of installation, this should give them no excuse (spacing).
    KL
    TV : Panasonic TC-54PS14
    Blu-Ray Player : DMP-BD65
    Receiver : Harman Kardon AVR 235
    Remote Control : Logitech Harmony 650
    DVD/CD Player : Panasonic DVD-F87
    Subwoofer : Paradigm PDR-10
  5. #5
    rockymtnman is offline Enthusiast rockymtnman is a forum member in good standing
    Join Date
    Oct 2006
    Posts
    15
    Thanks Given
    0
    Thanks Received
    0
    Default hdmi switching or upscaling?
    What is the difference bitween switching and upscaling and up conversion? Also, if I buy a receiver that has switching, do I need to get a dvd player that is already hdmi capable to have the hdmi quality? I am getting the Westinghouse lvm42w2.
  6. #6
    MDS
    MDS is offline Audioholic Spartan MDS should be listened to
    Join Date
    Oct 2004
    Location
    Austin, TX
    Posts
    6,683
    Thanks Given
    106
    Thanks Received
    763
    Default
    Quote Originally Posted by rockymtnman
    - Switching: all receivers switch between sources. If you have a dvd player and a set-top box connected to the receiver, when you press 'dvd' the receiver switches to the dvd player; ie the video and the audio now comes from the dvd player. Press 'Video1' (if that is the input where the set-top box is connected) and now all the audio and video comes from the set-top box.
    - Upscaling: Changing from one resolution to another. If eg you are viewing Standard Definition video from a DVD with a resolution of 480i and you have the receiver or dvd player set to upscale to 720p, then it adds lines to the image so that its resolution is now 720 lines instead of 480. The purpose is to match the resolution of the TV. Some receivers and dvd players include upscaling and all HDTVs scale.
    - Upconversion: The technical term is actually 'transcoding'; ie changing from one format to another. Upconversion is sort of the simplified colloquial term that everyone uses instead. Upconversion is for the case where you have different source devices using different connections and you want to output using one common connection. For example, the dvd player is using s-video and the set-top box is using composite video but you have component video connections to the TV. The receiver can convert composite and s-video to component video.
    The dvd player has to have hdmi outputs. If your receiver has hdmi inputs and outputs you can connect it to the receiver instead of directly to the tv and the receiver can switch between it and other connected devices. If you want to use HDMI output to the TV along with other devices that do not have HDMI outputs, then the receiver must also be able to transcode the other formats (composite, s-video, component) to HDMI.
  7. #7
    Join Date
    Oct 2006
    Posts
    15
    Thanks Given
    0
    Thanks Received
    0
    Default
    Quote Originally Posted by MDS
    thanks for your help....is there a device that will upscale and/or transcode that can be added to a system if the receiver doesn't have that capability?
  8. #8
    MDS
    Join Date
    Oct 2004
    Location
    Austin, TX
    Posts
    6,683
    Thanks Given
    106
    Thanks Received
    763
    Default
    Sure. DVDO is one that seems to be highly regarded. I have no experience with any of them personally but you might try a search of the forums because they have been discussed many times. Use search terms like 'video scaler', 'upconversion', 'transcoding', etc or even post a new topic and you're sure to get good replies from those knowledgeable about video.
  9. #9
    Join Date
    Oct 2006
    Posts
    15
    Thanks Given
    0
    Thanks Received
    0
    Default
    thanks again MDS, I appreciate all your insight.
  10. #10
    pjviitas is offline Audioholic Intern pjviitas is a forum member in good standing
    Join Date
    Nov 2006
    Posts
    30
    Thanks Given
    0
    Thanks Received
    0
    Default
    HDMI is a good send for folks who connect computers to their A/V systems
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
