Results 1 to 6 of 6
Thread: Halo 3 Legendary Review - a Journey, a Way of Life
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Halo 3 Legendary Review - a Journey, a Way of Life
    Ok, there are a hundred other reviews out there that are surely very informative as to the content of this game. I am a home theater enthusiast so I want to touch on the good and bad of the game from an audioholic perspective. I know, when you look at my mini blog up there, it looks like I am some kind of fanboy, but rest assured that I am as critical as the next guy...
    Discuss "Halo 3 Legendary Review - a Journey, a Way of Life" here. Read the article.
  2. #2
    autoboy is offline Audioholic autoboy is gaining some recognition
    Join Date
    Jan 2007
    Posts
    163
    Thanks Given
    10
    Thanks Received
    15
    Default
    I gotta say that I'm impressed with the game. It really does play just like Halo 2, but that is not a bad thing. The LFE is really pretty impressive on my SVS PB12 NSD.
    There is one thing I am disapointed in, and that is the jaggies. I had to double check to make sure I hadn't set the resolution to 1080i last time I traveled with my xbox. I was playing on a 56" 720P samsung DLP from 8-10 and the jaggies were really bothersome. Oh well, I'm sure after a few more days I'll get used to it.
  3. #3
    Seth=L's Avatar
    Seth=L is offline Audioholic Overlord Seth=L should be listened to
    Join Date
    Sep 2006
    Posts
    12,034
    Thanks Given
    1,204
    Thanks Received
    1,652
    Default
    Quote Originally Posted by autoboy View Post
    Aren't most video games this way thought?
  4. #4
    Wafflesomd's Avatar
    Wafflesomd is offline Senior Audioholic Wafflesomd should be listened to
    Join Date
    Aug 2006
    Posts
    726
    Thanks Given
    3
    Thanks Received
    70
    Default
    Would you like your game to run at 60fps or 30fps?
    You're going to get jaggies on consoles, anti-aliasing requires a lot of gpu power to pull off.
    And if you ask me, 1080p really isn't that high of a resolution. For tv's yes, but pc monitors have been beyond that for ages.
    Denying Rights to Music lovers.
    Denying Rights to Movie lovers.
  5. #5
    Join Date
    Jan 2007
    Posts
    163
    Thanks Given
    10
    Thanks Received
    15
    Default
    I thought that the system had been designed so that anti aliasing was easy on the GPU. 720P is a pretty low rez compared to PC gaming. I would think that the XBOX360 could handle some anti aliasing.
  6. #6
    Alamar's Avatar
    Alamar is offline Full Audioholic Alamar has a small fan club
    Join Date
    Aug 2007
    Posts
    353
    Thanks Given
    12
    Thanks Received
    48
    Default
    Note: My POV is from reviewing campaign .. not MP which is probably going to be the "big" thing with H3.
    While H2 & H3 have many similar things on paper the gameplay through the campaigns in H3 seems much smoother than what I saw in H2. Basically I do think that H3 is it's own game ... it's not H2.1 as some other people are saying.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
