Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Buzzing heard when using the Oppo 105
  1. #1
    little wing is offline Audioholic little wing is a forum member in good standing
    Join Date
    Sep 2005
    Posts
    123
    Thanks Given
    3
    Thanks Received
    3
    Default Buzzing heard when using the Oppo 105
    Hi Folks,
    I am hoping someone can help me.
    I recently purchased my first blue ray player (Oppo BD105) my receiver does not support HDMI, so my connections are as follows: HDMI out of the Oppo directly to the TV. 6 analog cables out of the Oppo to my receiver for 5.1 sound. I am also using the dedicated stereo output for CD playback. I noticed last night when watching Skyfall, that during quiet passages of the movie I heard a buzzing. When I paused the movie and listened, the buzzing becomes audible from my listening position at about -25.0 db. The buzzing is heard from all speakers when my receiver is in Multi-channal mode. The same buzzing is heard from the dedicated stereo outputs. I tried moving the player as far away as I could from my receiver (about 6 inches) They are side by side. I tried a heavy duty power cord I have. I also tried separating the cables behind the stand as best I could but it is still somewhat jumbled. I have everything plugged into a Monster Power Center HTS 2000. Anybody have any ideas?? Thanks.
  2. #2
    j_garcia's Avatar
    j_garcia is offline Seriously, I have no life. j_garcia should be listened to
    Join Date
    Jul 2005
    Location
    San Jose, Ca.
    Posts
    21,290
    Thanks Given
    1,664
    Thanks Received
    3,807
    Default
    You did not have this problem previously or perhaps did not notice it? It almost sounds like a ground loop issue. A power conditioner will not prevent ground loops. It ONLY happens with the Oppo or if you disconnect the Oppo and leave everything else as is also?
    HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
    System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
    Are you sure which side of the glass you are on?
  3. #3
    Join Date
    Sep 2005
    Posts
    123
    Thanks Given
    3
    Thanks Received
    3
    Default
    I did not have this problem before I installed the Oppo. My last DVD player was a 10 year old Onkyo that I had connected to my receiver via coaxial cable. My CD player was a Jolida, and the CD input on the receiver was dead quiet with nothing playing. I purchased the Oppo to replace both units. I hear the buzzing now when the Multi-channal or CD input is engaged on the receiver, even if the Oppo is powered off.
  4. #4
    fuzz092888's Avatar
    fuzz092888 is online now Audioholic Samurai fuzz092888 should be listened to
    Join Date
    Feb 2012
    Location
    A dream within a dream.
    Posts
    2,814
    Thanks Given
    1,181
    Thanks Received
    1,320
    Default
    What do you use for TV? I know I had a nasty humming and buzzing noise and it turnout out to be from my cable line. That's usually a pretty good place to start if you have one of those. The humming and buzzing is there no matter what as long as there is power to the thing powering your speakers (receiver or amps).
    "You're only given a little spark of madness. You mustn't lose it."
    Philharmonic Audio
  5. #5
    Join Date
    Sep 2005
    Posts
    123
    Thanks Given
    3
    Thanks Received
    3
    Default
    My TV is the Sony HX850. I have a Comcast cable box. Hdmi out direct to TV and coaxial out of cable box to receiver.
  6. #6
    fuzz092888's Avatar
    Join Date
    Feb 2012
    Location
    Posts
    2,814
    Thanks Given
    1,181
    Thanks Received
    1,320
    Default
    Try unscrewing the incoming cable line (the one that goes into the cable box) and see if that removes the noise. If so, that would be good and bad. Good in that you've identified the cause, but sort of bad because it means you need to buy a jensen transformer TRD something or other. If this doesn't help with the noise then it means you have ground loop hum and you'll have a lot of plugging and unplugging to do.
    Philharmonic Audio
  7. #7
    Join Date
    Sep 2005
    Posts
    123
    Thanks Given
    3
    Thanks Received
    3
    Default
    Quote Originally Posted by fuzz092888 View Post
    Looks like I got some work cut out for me tomorrow. Thanks! I appreciate it!
  8. #8
    fuzz092888's Avatar
    Join Date
    Feb 2012
    Location
    Posts
    2,814
    Thanks Given
    1,181
    Thanks Received
    1,320
    Quote Originally Posted by little wing View Post
    Btw, I'm not sure if you know what I was talking about, but the Jensen thing is small, costs about $50 and takes about 45 seconds to install.
    Philharmonic Audio
  9. #9
    Bryceo's Avatar
    Bryceo is offline Audioholic General Bryceo should be listened to
    Join Date
    May 2012
    Location
    Victoria wangaratta Australia
    Posts
    1,441
    Thanks Given
    378
    Thanks Received
    274
    Default
    Not verey help full but run and duck if that's the case!!
    Marriage is the only war where you sleep with the enemy!
  10. #10
    Join Date
    Sep 2005
    Posts
    123
    Thanks Given
    3
    Thanks Received
    3
    Default
    Thanks, no I was not aware of this. Is this device installed between the cable line in and the cable box?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
