Yes I have and if you ever find out a way to stop the OPPO from checking for updates let me know.
oppman99 is looking for a job at AH
Here's the situation. I've had my Oppo for quite some time and have been very happy with it except for one annoying detail. I still have the ability to play ISO files from a hard drive and don't want to update the firmware. I have repeately turned off the update notifications and even the networking, but every time I power up the player they are both turned back on and I get the new firmware notice. I'm afraid the gf will accidentally update the software.
I contacted Oppo customer service already and they responded that they had never heard of any similar issues. The suggestion was that I unplug the ethernet cable. Not really an option since I stream Netflix. Interested to know if anyone else has run into this issue. If you found a solution I'd love to hear it.
Paradigm Signature S8's V.2, JL Fathom F112, Emotiva XPA-1 x 2, Wyred4Sound DAC2
#1 Vincent Sp-331mkII amp, ATI 2002, Quicksilver's Mid Mono amplifier(2), Wyred for Sound STP-SE, (pre-amp), Rogue 99 Pre-amp, Jolida JD-9A, Micro Seiki bl-91, Kef 104.2, Usher be718, Rega Apollo, Sony xA5400ES, #2 Win7, Synology DS413 NAS w/Seagate 4 -2TB HHD, JRiver17, EE DAC Plus, Mytek DSD DAC, Genelec 8030A,Kef140
: #3 HT; Denon 4311Ci,GE Triton 2's, Sat50C, Sat3's, Rythmik D15se, OPPO-95,
The 83SE had a similar issue at one point, not retaining certain settings and it almost sounds like what is happening for you. What they told me was to clear the on-board cache, do a factory reset (will not affect the firmware) and then go ahead use it again, though everything should be default at that point and you will have to redo any settings you had. If it is not retained, it is possibly a flaw in the firmware you are running.
HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
Are you sure which side of the glass you are on?
oppman99 (07-11-2012)
More important...how's the DawgCrusher??????????
A bunch of Paradigm stuff, a big sub, a few amps and 3 plasma's...Panny of course...
That POS you sold me? It's long gone......j/k
The DawgCrusher is going strong. It's overkill for the size of the room I have it in, but I'm still lovin it. No need for bass shakers in the couch here! What did you eventually settle on? I know you had JL and SVS subs for a while.
Hocky is looking for a job at AH
Block oppo's ip range in your router and then it can't check for updates.
Martin Logan Summit X, ML Stage, 2xML Vignette, JL F212, Marantz AV7005, Aragon 8008x3, Emotiva UPA-2, Oppo 93, Squeezebox Touch, 6TB media server, Panamax 5400, 73" Mitsubishi
