Buy an used Marantz off of eBay. They have a great sound, well-built and go for reasonable prices.
Jim
I want a dedicated cd player. No Dvd, BluRay, Streaming, yadda yadda...
just a dedicated cd player that I don't have to put the tv on and go through the menus in order for it to start playing the cd. I also want something vintage (80's) and built like a tank, but not entirely necessary, but the rarer the better. An optical or coax out is preferred because I want to buy the Emotiva DAC to go with it.
jaymz is a forum member in good standing
Jim
I have a couple of 80s CD players that I don't think I will have a use for. Both are built like tanks.
One is a top end Denon.
The other is a top end Revox that I have had since new 1984. There is a mechanical problem with this one at the moment, but I'm sure I can fix it fairly easily.
Let me know if you are interested.
Marantz DV 9600 Oppo BD-83 Marantz AV 8003 Quad current dumping amps X 7 Direct TV HD 20 HD DVR Carter audio workstation RME Fireface 800 Fujitsu 50XHA40 Front left and right Carter dual transmission line studio monitors MK II. Center Carter coaxial transmission line center speaker Rear Carter NFM-1s Center backs Carter dual transmission line studio monitors MK I. My system: - http://mdcarter.smugmug.com/gallery/...27077317_Pufg7
If you are using an outboad DAC, any CD player with a working digital out will sufficie. As long as the external DAC can differentiate the ones and zeros, they will be equally reproduced irrespective of "transport" used.
If you intend to use the analog outs on said player, the onboard DAC comes into play. In this case, I'd recommend an used Denon 3910.
Home Office: Behringer 1030A, SVS PB-12 Ultra, measured. Comfy Room: PS3, Sennheiser RS120, Samsung UN46B8500. On the Go: Sansa Clip lost, Etymotic ER-6i commandeered by wife!
HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
Are you sure which side of the glass you are on?
Yep another vote for Denon. I have a 5 disc changer for about 20 years no problem at all. DCM-320 is my model. Oh look one on ebay: http://www.ebay.com/itm/Denon-DCM-32...#ht_500wt_1287
No it doesn't do it all the the time, but depending if it connects to the internet or not is when it does it. It downloads the titles and album image, and also it takes what seems like forever for it to boot up. I realize this isn't an necessity, but it is something I want to do "just because". Also, everytime I turn on my bluray it turns the TV on, and if I turn my TV off, the player shuts off. And yes I know I can bypass this, or by a CD player.
