Audioholics Home Theater Forums
store.audioholics.com EMPTek.com BlueJeansCable.com Emotiva.com VisualApex.com Yamaha.com/yec SpectraCal.com CEDIA moshimonde.com SVS Sound Subwoofers
Go Back   Audioholics Home Theater Forums > Home Theater Hardware Hangout > CD/DVD/Blu-ray & Misc Hardware
Reply
LinkBack Thread Tools Rate Thread Display Modes
  #41
Old 01-31-2012, 08:17 PM
Fanboyz is a forum member in good standing
Default
Hey first post:
I just got an Oppo 93 and sometimes when first spinning up a disc it makes a very feint whining/squealing noise, this only lasts for like a second- and it's very quiet. It's almost imperceptible, it's like the noise CRT TVs made but almost inaudible. I think most people may never be able to hear it, but I can.
It only does this after the machine has been off for a while and not on every disc.
This never happens during an actual movie and Oppo doesn't sound very interested in my issue, at least one other user on another site also noticed this, have any of you guys noticed this? Is this a glitch or normal operational noise.
  #42
Old 02-02-2012, 01:28 PM
Wayde Robson's Avatar
Moderator
Wayde Robson should be listened toWayde Robson should be listened toWayde Robson should be listened toWayde Robson should be listened toWayde Robson should be listened toWayde Robson should be listened toWayde Robson should be listened toWayde Robson should be listened toWayde Robson should be listened toWayde Robson should be listened toWayde Robson should be listened to
Default
I haven't noticed but I'll listen.
It's not hard to imagine it could happen though, it's a mechanical device literally spinning up a disc. Those moving parts are liable to make some sounds, it doesn't seem like anything to worry about.
But like I said, I'll listen to mine when I get a chance tonight and let you know what I find.
__________________
Wayde
Tell me what you think in real time on Twitter @AudioholicsLive
  #43
Old 02-02-2012, 07:35 PM
Default
thanks.
It's very, very, quiet.
  #44
Old 02-04-2012, 05:35 PM
83benz240 is a forum member in good standing
Question 93 set up advice - newbie
I just received my BDP-93 and have a few questions about how to set it up:
Should I be using analog cables or HDMI for higher music quality? Right now the music is going through the HDMI cable even though I have the analogs connected as well.
If I am 95% concerned with music quality (I may RARELY watch a DVD), are there any other settings you all may recommend I try?
My set up is the 93 into a Pioneer SC-57.
Thank you in advance - this forum has been a great help to me so far. How do you know when you're not a "newbie" anymore?
  #45
Old 02-15-2012, 07:15 AM
Moderator
Default
I'm no authority but... it depends on if you think the DACs inside your receiver or in your Oppo are of the better quality. One way is to try a piece of music you know and love both ways to see if you can perceive any noticeable difference.
__________________
Wayde
  #46
Old 02-15-2012, 09:47 AM
haraldo's Avatar
haraldo should be listened toharaldo should be listened toharaldo should be listened toharaldo should be listened toharaldo should be listened toharaldo should be listened toharaldo should be listened toharaldo should be listened toharaldo should be listened toharaldo should be listened toharaldo should be listened to
Default
Quote:
Or.... forget about technique....
Just listen to what makes you enjoy the music the most.... which one makes you forget about technique.... and listen to at least a few songs at a time....
__________________
Do not ask en engineer to explain, Because he will
  #47
Old 03-14-2012, 05:01 PM
Moderator
Default
Does anyone know where/how I can get the last firmware version from Oppo for the BDP93?
I need to downgrade... I accidentally got the one that that went out on the 6th that removes the iso playback capability.
__________________
Wayde
  #48
Old 03-14-2012, 07:03 PM
PENG should be listened toPENG should be listened toPENG should be listened toPENG should be listened toPENG should be listened toPENG should be listened toPENG should be listened toPENG should be listened toPENG should be listened toPENG should be listened toPENG should be listened to
Default
I have saved an older version for my 95, but I don't think you can downgrade that easy.
  #49
Old 03-14-2012, 11:08 PM
cpp's Avatar
cpp cpp is offline
cpp is looking for a job at AHcpp is looking for a job at AHcpp is looking for a job at AHcpp is looking for a job at AHcpp is looking for a job at AHcpp is looking for a job at AHcpp is looking for a job at AHcpp is looking for a job at AHcpp is looking for a job at AHcpp is looking for a job at AHcpp is looking for a job at AH
Default
I got this in my email today
"""A new firmware was released for your OPPO BDP-93/BDP-95 Blu-ray player on March 6, 2012. Learn more about this new firmware and how to get it.
@ OPPO BDP-93 Blu-ray Disc Player
Version BDP9x-65-0302
Loader Version: CN0900
Sub Version: MCU93-09-0218 (BDP-93), MCU95-08-0218 (BDP-95)
The firmware is the system software that controls the features and functions of the player. Since the Blu-ray Disc specifications are still new and evolving, it is quite possible that recently-released Blu-ray discs use certain new features that were not available when the player was designed and sold. To ensure the best viewing experience, it is important to keep the player’s firmware up-to-date. If your OPPO Blu-ray player is connected to the internet, you may upgrade the player directly over the internet."""
"""This version is designed for the OPPO BDP-93 and BDP-95 Blu-ray Disc players. Comparing to the previous Official release version BDP9x-61-1219, the major changes are:
1) Per request from the studios, the ISO file playback function has been removed in this firmware version. The previous firmware had the ability to play ISO files, but it was an undocumented function and was never officially announced or supported. Future firmware revisions will no longer support ISO playback.
2) Resolved the loading failure observed on several recently released titles, samples like "Hugo (BD, 2012)" and "Rio (BD, 2011)". The failure only happens with the 2D version Blu-ray disc, where the TV shows only a black screen and the player's front panel display would remain at 00:00:00. This firmware can properly load and play these titles.
3) Improved video up-conversion quality over the HDMI 1 output for 720p source material. This improvement provides a better picture quality for Netflix streaming as well as 720p-encoded Blu-ray discs.
4) Resolved the loading failure issue observed on several recently-released Blu-ray movies, mainly Universal Europe (EU) releases. Their US releases have no known issues. Sample titles include "Jurassic Park Trilogy (BD Box Set, 2011)", "Kong Fu Panda 2 (BD, 2011)", "Fast Five (BD, 2011)", and "National Lampoon's Animal House (BD, 1978 version)" etc. With the previous firmware, disc playback will automatically stop once you go to the Main Menu and select PLAY. This firmware properly loads and plays all of the above Blu-ray titles.
5) Resolved the audio channel loss issue where DTS-HD MA 6.1 audio is decoded as 5.1 for both the analog audio outputs and the HDMI LPCM output. Sample titles include "Star Wars: The Complete Saga (BD, 2011)" and "The Lord of the Rings: The Motion Picture Trilogy (BD, 2011)". The reason is the Center Surround (CS) channel is folded into Surround channels (SR/SL) instead of Surround Back channels (SBR/SBL). This firmware decodes this 6.1 audio as 7.1 by distributing the CS channel to the SBR/SBL channels, and send out through HDMI and analog audio outputs.
6) Resolved the freezing issue observed when accessing some BD-Live features. Samples include the "Extras" in "Puss in Boots (BD, 2011)", the "Disney Virtual Vault" in "The Lion King (BD, 2011)".
7) Provided smaller volume control adjustment steps through the Analog audio outputs. Previously the Volume Control adjusts at 5 per step in the index and 2 dB per step in the level. This firmware allows volume control at 1 per step in the index (100, 99, 98, 97, ...), 0.5 dB per step in the level for BDP-95, 1 dB per two consecutive steps in the level for BDP-93 (e.g.,indexes 100 and 99 share the same volume level).
8)Improved general disc compatibility based on recent and upcoming Blu-ray releases as well as user-submitted disc samples including "Mr. Poppers Penguins (BD, 2012)", "Dragons Gift of the Night Fury (BD, 2012)", "Human Planet (BD, BBC Documentary)" and "Nine Inch Nails, Live - Beside You In Time (BD)"."""
__________________
#1 Vincent Sp-331mk amp, Quicksilver Stage Pre-amp, Jolida JD-9A, Usher Be-718, Reynuad Offrande Supreme, Rega Apollo, Win7, Seagate 4TB NAS, JRiver17, EE DAC Plus ,Micro Seiki bl-91,
: #2Denon 4311Ci, ATI-1800, GE Triton 2's, Rythmik D15se, Sat50C, Sat3's, Kef 103.2 (2), OPPO-93,
want: Philharmonitors, Phil2's, case of Pyrat Cask 23
  #50
Old 03-15-2012, 09:51 AM
Moderator
Default
I'd like to keep the iso compatibility as long as possible.
The patch info mentions improvements to 720P Netflix streaming. Has anyone tried to stream Netflix from this device? I find it unusably slow to navigate the movie titles. It's not my network speed because I can switch to PS3 and I can scan through movie titles fast and flawlessly.
The Oppo seems to take forever to load the first screen of movies, then once you try to scroll around you're in for several more such waits.
__________________
Wayde
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Copyright 2011 AUDIOHOLICS, LLC
