Results 1 to 4 of 4
Thread: Panasonic BD35K + Denon 2807
  1. #1
    dpnaugle's Avatar
    dpnaugle is offline Junior Audioholic dpnaugle is a forum member in good standing
    Join Date
    Apr 2006
    Posts
    69
    Thanks Given
    0
    Thanks Received
    0
    Default Panasonic BD35K + Denon 2807
    Is the Panasonic BD35K a good choice to pair with a Denon 2807. I am coming from an HD-A2 and hope that some of the load time can be cut down.
    Any other/better players to consider in the $300 range?
    Denon AVR-2807
    Paradigm Studio 60 v4
    Paradigm Studio CC-590
    2-Paradigm Studio ADP-590
    SVS SB-12 Plus-Piano
    Sony E55A20
    Toshiba HD A2
    http://myht.shutterfly.com/action/
  2. #2
    Phil Taylor's Avatar
    Phil Taylor is offline Senior Audioholic Phil Taylor is looking for a job at AH
    Join Date
    Jan 2006
    Location
    OKC, OK USA
    Posts
    745
    Thanks Given
    175
    Thanks Received
    195
    Default
    The Panny would be a great match with any system IMHO. Load times seem to vary by disc but are not unreasonable. A link to the long load times and slow command response is dependent upon whether the player is connected to a network. The consensus seems to be to only connect it to a network if you want to update firmware or use the BD Live features - otherwise leave it disconnected. Mine is not on my network and it responds to commands instantly and loads discs quickly.
    Certifiable Home Theater Systems Nut
  3. #3
    Austin M is offline Enthusiast Austin M is a forum member in good standing
    Join Date
    Nov 2007
    Posts
    22
    Thanks Given
    3
    Thanks Received
    3
    Default
    I have this receiver and was thinking about this combo as well. I think we have HDMI 1.1, so all the HD codecs should decode internally and pass through as PCM just fine, correct?
  4. #4
    jostenmeat is offline Audioholic Spartan jostenmeat should be listened to
    Join Date
    Feb 2007
    Posts
    6,781
    Thanks Given
    3,090
    Thanks Received
    2,902
    Default
    Yes. If it accepts mch PCM, then yes. There is not a better player than the BD-35 for the money. Whether considering different aspects ranging from pure and simple Bluray PQ, to the ease and simplicity of switching audio output selections, to the FW support. There is not a better bluray player for the money.
    The only cons are that it can't output DVD at 480i for outboard VP, and the faceplate is not as pretty as the competitors.
  5. The Following User Says Thank You to jostenmeat For This Useful Post:
    Austin M (12-17-2008)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
