Connect the pre-amplifier outputs (pre-outs) for "A" to the two inputs on the power amp; makes more sense that the amp is just not using left/right labels, and uses A/B arbitrarily....I have amps that simply say channel 1 and channel 2. I didn't get that particularly or I would have said connect the A pre-outs to the A/B inputs on the amp
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I was thinking more your amp had both A/B speaker capabilities (didn't see a pic of the rear panel of one either and yours isn't a lot of help in that regard).
An online manual would be helpful but I didn't see one, so not sure if the tape loop I saw mentioned in an article/review is a good option or to just put the equalizer in between the pre-amp and amp.
Not sure what model your sub is or what it has for connections but if a typical plate amp for a powered sub, hopefully it has both L/R rca inputs and can let the sub sum the signal to mono (also assuming your pre-amp can use both A&B outputs simultaneously). Not sure what you mean about skipping power.
If you do want more options to integrate a sub/subs let us know and we can give you some thoughts on that, but I do think its time to think about a new sub/subs!
