Yammy RX-V2600 OR Pioneer Elite VSX-56Txi?
MelodyMonster
Hello everyone,
Happy New Year!!!!
I have been looking for a new receiver for a while now and has led me into a total confusion....RX-V2600 or VSX-56TXi or VSX-74Txi ????:eek:
I like to have all the latest features and connections but at the same time I don't want to compromise on the performance...It looks like the RX-V2600 has lots of features but 56Txi could be better in sound and performance (not sure though :rolleyes: )
I will use the system for DVD's for the most part and music ocassionaly (70:30 split)....
Also, anyone have any idea about the VSX-74Txi (as compared to VSX-56Txi). I know it has more features like iPod and Sirius but not important for me...
Looked at Denon's, but they are a little over budget.....:(
In your educated opinions, which of the two receivers would bit the G-spot.....
MelodyMonster said:
Hello everyone,
Happy New Year!!!!
If you are after the latest features, that is what you have to compare, which has what you really need, including the video side of the house:)
Speakers have a bearing on the component's power requirements. After that, I would not worry much.
V
Vigor
MelodyMonster said:
Hello everyone,
Happy New Year!!!!
The VSX is a true 110WRMS X 7 with the latest features and connections, it is a good receiver, you need a good speakers the performance is overwhelming. I find the VSX more friendly & easy to use. if you can go for VSX-74TXi you will have more features but if it is not important for you the sound is the same.
Jeje2
I was comparing the AX4AVi (In USA: 74Txi) and RX-V2600.
I went for the Yammy - main reasons:
  • Yamaha has for each input the audio level adjustment (Can even out different sources)
  • Yamaha has upscaling for picture (480i [576i] -> 480p [576p] -> 720p -> 1080i)
  • Yamaha was little cheaper than the AX4AVi
  • Yamaha provides superb support for other remotes (Have programmable remote HTM MX-700)
I've been :D with the sound of my new receiver (damm my Sub never sounded so good) - will get to picture evaluating in a couple of weeks when my projector arrives.
MelodyMonster
Thanks for the input. I went to my local Tweeter store and from the looks and features, I liked the 74Txi the most. I am going to go back with some of my cds/dvds as well as my iPod and hear it.
Video upconversion is not something I am looking at this point and I think one can by a DVD player that does the upconversion and upscaling stuff.
Does anyone know how much does 74Txi receivers go for? The local tweeter has it for $ 1500.00....
